1981 Kawa 650 (With 750 engine)
  • gordone
  • gordone's Avatar Topic Author
10 Jan 2017 10:14
#751869
I have bought bike I want to build to a cafe racer, have some fun project for some winters, no stress, working in the winter and driving in the summer :)
I have started to clean and rebuild the carbs, want to make sure it working 100% techincal, before I start to rebuild the look.
I have started to looking for seat, do you have any site/webpage you recommend for bying seat, good quality?
Thank you.
Project:
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
Re: 1981 Kawa 650 (With 750 engine)
10 Jan 2017 11:54
#751880
Looking forward to your project.
Check out the Do The Ton Café site.
Lots of links to parts suppliers.
www.dotheton.com/forum/index.php
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2 Project
  • martin_csr
  • martin_csr's Avatar
10 Jan 2017 13:16 - 11 Jan 2017 06:22
#751896
If you just want a seat cover, here's one I'm thinking of getting. It has Kawasaki stenciled on the rear, similar to the stock seat. I already recovered a spare 750 Ltd seat w a nos Travelcade/saddlemen/saddle-skins seat cover which is now on the bike, but I'd like to put the original seat back on the bike w the stenciled cover. Recovering a seat is kind of a pain, but doable.
eb --- Motorcycle seat cover - Kawasaki KZ650CSR --- UK seller ... probably available on eb UK
Last edit: 11 Jan 2017 06:22 by martin_csr.
  • rrsmsw9999
  • rrsmsw9999's Avatar
10 Jan 2017 14:42
#751910
I forget the seller on ebay but he makes a lot of vintage covers. 35$. If you want the name I can look it up, but the product was A++++, nice supple thick padded codura vinyl. Stitching and fit was perfect. A tip I would say is if your seat pan has any damage get a metal upholstery rail to rivet to the pan. The old tines even when not rusted will be brittle and weak. Most times the stock foam and pans are fine for reworking with upholstery. R
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
  • kaw-a-holic
  • kaw-a-holic's Avatar
10 Jan 2017 19:40
#751924
These are great guys to deal with. Even if you don't buy from them you may find some inspiration for a DIY project.
www.dimecitycycles.com/motorcycle-parts/...13.html?cat=2218&p=1
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
  • gordone
12 Jan 2017 09:43 - 12 Jan 2017 09:47
#752013
No eBay APP ID and/or Cert ID defined in Kunena configurationThank you all for the information, have not found the look I want for my bike, I`m looking at pictures, but for the seat I think I want to have something like these :
temp.dynamitt.net/div/MC/01.JPG
I`m open for inputs, don`t think I want to have the orginal seat.
I can see people ar cutting of the frame behind and welding new 180 degress bend ?
Some hind the battery inside the end of the seat ?
When I`m looking at pictures of cafe racers I often don`t see the tag plate .... I need to have it :)
Project:
Last edit: 12 Jan 2017 09:47 by gordone.
  • gordone
13 Jan 2017 15:32
#752144
While I`m waithing for parts to rebuild the carbs have I today done a compressor test and valve clearance measurements.
C1 = 6.2 bar = 90 psi
C2 = 6.2 bar = 90 psi
C3 = 5.8 bar = 84 psi
C4 = 6.3 bar = 91 psi
Valve 1 = 0,25 mm
Valve 2 = 0,30 mm
Valve 3 = 0,15 mm
Valve 4 = 0,15 mm
Valve 5 = Was not able to get 0,15mm in.
Valve 6 = 0,20 mm
Valve 7 = Was not able to get 0,15mm in.
valve 8 = 0,10 mm
What do you think about the test results ?
Project:
  • JR
  • JR's Avatar
13 Jan 2017 15:50 - 13 Jan 2017 21:31
#752146
Low compression figures.
Was the engine warm and did you hold the throttle wide open ?
On my 1980 750/4 the valve clearances should be 0.08 to 0.18mm (.003 to .007 inches I think) so most of those measurements you posted would be way out.
What does your manual say?
Last edit: 13 Jan 2017 21:31 by JR.
13 Jan 2017 16:24
#752148
gordone wrote: While I`m waithing for parts to rebuild the carbs have I today done a compressor test and valve clearance measurements.
Valve 1 = 0,25 mm
Valve 2 = 0,30 mm
Valve 3 = 0,15 mm
Valve 4 = 0,15 mm
Valve 6 = 0,20 mm
valve 8 = 0,10 mm
Please describe how you did the compression test. It should be done with all spark plugs out; the engine warmed up to normal operating temperature (the pistons are tapered toward the top and must be warmed up to expand); throttle wide open; fully charged battery; etc. Ed
  • gordone
14 Jan 2017 03:17
#752167
Hi,
The carbs is not mounted, all sparks plugs what out.
I attached the compression tester to each cylinder and let the start motor run until the pressure was not increasing any more.
The motor was cold duo to rebuild the carbs...
So cold motor has a big impact ? I must then re test when I got my carba installed again.
Thank you for your inputs.
Project:
  • Nessism
  • Nessism's Avatar
14 Jan 2017 05:09 - 14 Jan 2017 05:10
#752170
Those compression numbers are low but you have a bunch of tight valves so that isn't helping. Also understand that often times the compression will be low on an engine that has been sitting for some time. I'd adjust the valves, clean the carbs, and get the bike running. Then give the bike an Italian Tune Up for a few hundred miles and then check compression again. Dollars to donuts the compression numbers improve.
Last edit: 14 Jan 2017 05:10 by Nessism.
  • gordone
14 Jan 2017 16:49
#752203
Thank you for inputs, yes I cleanred the gas tank today. Have ordered part for the carbs, so while waiting for parts for the carbs I will focus on the valves, I need to read more to see if I have mesaure correct and also learn how to adjust them :)
Project:
