Racing my 650 hot street bike
- leitz
Re: Racing my 650 hot street bike
10 Mar 2016 11:27
I did a photoshop of what I wanted on Z900 with Bulldock seat pic. Tank will be on raw iron with coat.
I´ll try to do it on my smaller z650
Attachment 2morad.jpg not found
- leitz
09 Apr 2016 00:53 - 09 Apr 2016 01:06
I´ve mounted Andrews cams on stock 650 cam sprockets and this is the result:
In: 116 degrees lobe center
Ex: 108 degrees lobe center
I need 105 lc so i´m off 11 degrees on the intake and 3 on exhaust. I need to slot the sprockets
Is too much a correction of 11 degrees? Is it safe?
Last edit: 09 Apr 2016 01:06 by leitz.
- turboguzzi
09 Apr 2016 07:09
you need indedd slotted sprockets and do the full "cam degreeing" process
www.enginelogics.com/degree-dual-overhead-camshafts/
i am pretty sure you will find a better manual for kawi motors degreeing if you googgle
you will also need for this a dial indicator and timing wheel,
it's not so hard if yo know what you are doing, but if its your first time, maybe let a good mechanic with tuned motor experience do it.
actually, it is not safe to run the motor with the numbers you have now.... dont try to turn it around, you might bend a valve...
- leitz
09 Apr 2016 09:45 - 09 Apr 2016 09:49
I placed the Andrews in stock position with stock sprockets and get the measurements like in the link you have sent with a dial gauge and a timing wheel:
9/62 at intake so 116 lc
53/16 at ex so 108 lc
Andrews #20 data sheet: 26/56 int. and 56/26 ex. and 110 degrees lc but seller said me to install them at 105 lc so i think at 21/51 in. and 51/21 ex.
I suppose i have to slot the sprockets to gain 11 degrees on intake and 3 on exhaust for 105 lobes
I'm wondering if I should return to the stock cams :S :S
Last edit: 09 Apr 2016 09:49 by leitz.
- turboguzzi
09 Apr 2016 10:06
yes, 105 lc is the common figure on kz, 110 will make the engine need lots of revs to make power
slotting the cam wheels is no big deal, you could even do it with a dremel stone, but it will take time....any machine shop should be able to do it on a mill
plus, are you measuring with a dial indicator and the correct 040"/1mm lash? if you are just going by feel when the cams touches the bucket, its very easy to get mistakes because of the cam ramp
nobody said setting up a race bike is super easy....
- missionkz
09 Apr 2016 10:30.040-1MM? That seems extremely wide. Maybe .004" and .01mm?turboguzzi wrote: yes, 105 lc is the common figure on kz, 110 will make the engine need lots of revs to make power
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
1977 KZ1000A1
- leitz
09 Apr 2016 11:06
I´ve checked it at 0.030" (0.76mm) valve lift like Andrews claims
- missionkz
09 Apr 2016 11:22Lift and Lash are two totally different things.leitz wrote: I´ve checked it at 0.030" (0.76mm) valve lift like Andrews claims
Bruce
1977 KZ1000A1
1977 KZ1000A1
- leitz
09 Apr 2016 11:44 - 09 Apr 2016 11:51
Zero lash.
I check the cam timing at running lash and deduct the lash from 0.030" to obtain the correct checking lift. ( info from Megacycle cams)
0.030" (valve lift) - 0.005 (my running lash)= 0.025
I check opening and closing points at 0.025" (0.63mm)
Last edit: 09 Apr 2016 11:51 by leitz.
- kawi810
09 Apr 2016 11:46
what are you using to push down on your cam chain?if the answer is nothing thats why you have a large different L.C.between intake and ex.
original owner of a 1984 gpz 750
1985 turbo 750 stock, being restored.
1984 gpz 750 with 810 cc wiesco's megacycle cams(471-10) 34 mm flatslides v&h pipe ported head dyna ignition. bottom end, crank case from turbo 750 and sprockets.
- leitz
- kawi810
09 Apr 2016 12:17 - 09 Apr 2016 12:18
did you check TDC with the positive stop method? and cam chain is adjusted?
Last edit: 09 Apr 2016 12:18 by kawi810.
