Supercharged and EFI 1975 Z1 900 KZ 1000 Drag Bike
- Gypsy Road
Re: Supercharged and EFI 1975 Z1 900 KZ 1000 Drag Bike
30 Jan 2016 18:50Attachment Mockupofthrottlebody.jpg not found
Mock up of throttle bottle
Attachment Fuelsystemandwiring.jpg not found
While waiting for parts from the machinist I have started installing the fuel system
- Nebr_Rex
30 Jan 2016 22:56Gypsy Road wrote: The photo with the blue tank is what it looked like when I first brought it home.
Here is the Supercharger as I pulled it from my dad's shelf.
Attachment Bloweronmydadsshelf.jpg not found
Mocked up on bike
Attachment MockupofChargerleftsidecloseup.jpg not found
Is that an Eaton m45?
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- Gypsy Road
31 Jan 2016 03:48Nebr_Rex wrote:Gypsy Road wrote: The photo with the blue tank is what it looked like when I first brought it home.
Mocked up on bike
NE Rex it is a Eaton m90
- Gypsy Road
01 Feb 2016 16:41
I found the original Craigslist posting I had saved so I thought I would share.
In the garage as it sat on the day I purchased her. It was like 5 degrees that day!
Here it is all loaded up heading for home
Attachment Craigslist.png not found
Attachment CLright.png not found
Attachment CLleft.png not found
Attachment CLrear.png not found
Attachment Backoftruck.jpg not found
- z1kzonly
02 Feb 2016 04:36
Will be cool! Sure looks like you know what your doing also!
I will give up my Girlfriend and my 1st born for that old Woodie rim :laugh:
The Harley Drag Bike guys used to use them in the early 80's with the 7" Goodyear slicks
- Gypsy Road
02 Feb 2016 09:34
Thank you For the kind words Z1kzonly.
When I bought my first street bike back in 1991 it was a 73 Z1 it had a 4"? wide alum spoke rear rim. I wanted the 8" wide but could not afford it. Plus all the other mods that went with it. I am building the bike I wish I could have had when I was a kid. Chasing my youth........
Not sure I know what I am doing? I blew the main fuse 3 times while wiring the bike. but I am sure learning a lot!
- Gypsy Road
08 Feb 2016 16:43 - 08 Feb 2016 16:45
Been working it some and have some photos of some things I have already completed. We made some headway with the machined manifolds this week. Jim finalized the design and should be cutting parts next week. Fingers crossed
New key and hour meter installed
Made some tiny tabs for mounting plates and items to the frame
tabs used to attach plates
Yamaha R6 regulator mounted and wired in
Jim got the snout of the blower machined and collar made. The support plate that will run from crank drive up to the blower it will bolt up to this collar.
Attachment IMG_20160201_155812611.jpg not found
Attachment TabsandPlate-2.jpg not found
Attachment regulator.jpg not found
Attachment machinedsnout.jpg not found
Last edit: 08 Feb 2016 16:45 by Gypsy Road.
- Gypsy Road
08 Feb 2016 16:47
Here is the tabs before I cut them from a sheet
Attachment Sheetoftabs.jpg not found
- PLUMMEN
08 Feb 2016 21:54Yep,thats the add I remembered.Gypsy Road wrote: I found the original Craigslist posting I had saved so I thought I would share.
- Gypsy Road
09 Feb 2016 15:34
PLUMMEN,
I waited two weeks after I first seen it on Craigslist hoping it would be gone when I called him. When I called him and he still had it I knew I was in trouble................
- Gypsy Road
09 Feb 2016 15:50Attachment Brakestayarm.jpg not found
Brake stay arm. I constructed out of some alum round stock. drilled and tapped each end installed heim joints. Then polished
Attachment Brakestaybracket.jpg not found
Bracket made. Going to try to get time to weld it on this weekend
10 Feb 2016 06:21
diggin all the fab work keep us posted,
