The Martyr Machine project, codename "Haggard"
  • dom2570
  • dom2570's Avatar
Re: Re:The Martyr Machine project, codename "Haggard"
03 Nov 2015 20:02
#697123
martin_csr wrote: You should compare stuff for yourself, but as reported by others it should be a direct swap. Most if not all of the 440s have the same output shaft & rear wheel stuff. The Ltd belt chain guard is the same as the 440A & they have the same chain guide at the front pulley/sprocket. Remove the pulleys & belt, then install the sprockets & chain. The conversion is usually done because a replacement belt is NLA.
On the belt drive, there is one mount for the guard that will need to be removed if you convert to a chain.
Whip it like a mule!
