1976 KZ400-S2 Cafe/Brat
- ZeffRides
22 Sep 2015 04:16 - 22 Sep 2015 05:57
Working on taking this abused KZ400 to a better state! Progress may be slow since this is my first build and as you all know, sometimes parts are scarce. The PO did the awful paint job, all of which will be removed eventually. Right now it doesn't run, engine is not seized and seems to have decent compression (still need to check), I've replaced spark plugs, plug caps and also fashioned up some new air duct boots. Oh and I removed the rear fender because it was bent up real bad and mounted terribly.
Progress Update #1 - Carbs/Petcock
Last night I just finished up COMPLETELY dissembling the carbs, I mean every single last O-ring and screw has been taken out. Next I have to strip the awful red paint, clean, replace worn O-rings, and hopefully get put back together in a timely fashion. I also have the petcock pulled off and I already stripped the paint from it. This thing had a good amount of junk in it :S but I'll be replacing all seals and that home-brew looking screen. I'll continue to update this post as I continue along. For those interested, after the carbs I plan on checking out the condition of the starter and getting the points set and HOPEFULLY going to be able to get this thing started.
Attachment 091615-3-2.jpg not found
Attachment 091615-4-2.jpg not found
Attachment 091615-1-2.jpg not found
Attachment IMG_0009.jpg not found
Attachment IMG_0010.jpg not found
Attachment IMG_0011.jpg not found
Attachment IMG_0029.jpg not found
Attachment IMG_0046.jpg not found
Attachment IMG_0047.jpg not found
Attachment IMG_0004.jpg not found
Attachment IMG_0005.jpg not found
Attachment IMG_0008.jpg not found
1976 KZ750B1
1978 CB750K
2002 BMW 530i 5-speed
1978 CB750K
Last edit: 22 Sep 2015 05:57 by ZeffRides.
- Kidkawie
- I bleed premix
Re: 1976 KZ400-S2 Cafe/Brat
22 Sep 2015 04:48 - 22 Sep 2015 04:48
There's two things people should need a license for:
1 ) spray paint
B ) JB Weld
Good luck. I bought a couple spray-bomb specials...never again.
1 ) spray paint
B ) JB Weld
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
Last edit: 22 Sep 2015 04:48 by Kidkawie.
- ZeffRides
Re: Re:1976 KZ400-S2 Cafe/Brat
22 Sep 2015 05:54
Haha couldn't be more true. And yeah this project will be a pain and very time consuming but it is oh so satisfying seeing that original metal underneath
1976 KZ750B1
1978 CB750K
1978 CB750K
- pete greek1
22 Sep 2015 07:02
With all that gunk in the petcock, how does the inside of your fuel tank look like ?,
- ZeffRides
22 Sep 2015 07:20
Haven't gotten to the tank yet, it could be quite scary. This bike sat in a barn for a good number of years so it's sure to have some junk in there.
1976 KZ750B1
1978 CB750K
1978 CB750K
22 Sep 2015 09:55
I highly recommend you add an inline fuel filter and put on a new fuel supply line before you hook the carbs back up to the tank. Even if you meticulously clean the tank a little, itty bit of junk hiding in a corner may make its way down into your nice clean carbs and foul them, and that would require you to clean them again (and again). Ed
- ZeffRides
22 Sep 2015 10:03
Yep I'm definitely going to add one in. This is such a meticulous task that the longer I can go without having to do it again, the better
1976 KZ750B1
1978 CB750K
1978 CB750K
- ThatGPzGuy
23 Sep 2015 01:43
Nice job. It feels good to bring them back, doesn't it?
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
- ZeffRides
23 Sep 2015 02:08
Oh its absolutely great! Got the paint all removed and taking them in for a ultrasonic cleaning this morning. By the way GPZ I remembered you mentioned you get your jets on power-barn and I went to look last night and was having a difficult time figuring out which ones fit my bike. I've got the CVB36 carb and I need a pilot jet, do you know the part number on power-barn?
1976 KZ750B1
1978 CB750K
1978 CB750K
- ThatGPzGuy
24 Sep 2015 01:38No sorry. I checked my notes and I only got the main jets from PowerBarn.ZeffRides wrote: By the way GPZ I remembered you mentioned you get your jets on power-barn and I went to look last night and was having a difficult time figuring out which ones fit my bike. I've got the CVB36 carb and I need a pilot jet, do you know the part number on power-barn?
Jim
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
- ZeffRides
24 Sep 2015 02:50
Ah okay, thanks anyways.
1976 KZ750B1
1978 CB750K
1978 CB750K
- Kidkawie
- I bleed premix
24 Sep 2015 05:15
If it's just clogged, I use a set of micro drill bits or a torch tip cleaner to clean them out.
1975 Z1 900
2004 KX125
2004 KX125
