Kz440 Project Picture Heavy
- DobbinsCMA
15 May 2015 14:35
I'm bringing a 150 dollar bike back to life!
What's going on with these plugs?
Now for an oil change and new gas. Then see if she starts with new battery. Then valve adjustment and exhaust fix. Get the brakes unstuck (maybe just the front or rear) and drive to get new tires put on!
Attachment image-4.jpg not found
Attachment image-5.jpg not found
Attachment image-6.jpg not found
'80 Kz1000B4
MTC 1075 .375 webcams Mikuni RS34
KZ440 Project
81'KZ750E2 Project
Past- '81 Kz750H
KZ440 Project
81'KZ750E2 Project
Past- '81 Kz750H
- DobbinsCMA
Re: Kz440 Project Picture Heavy
15 May 2015 14:37Attachment image-10.jpg not found
Also just saw the new Mad Max...wow. Old one had a Kz1000 but I didn't see one with this.
'80 Kz1000B4
KZ440 Project
81'KZ750E2 Project
Past- '81 Kz750H
KZ440 Project
81'KZ750E2 Project
Past- '81 Kz750H
Nothing wrong with those plugs as long as you plan to install them in a Ford. :laugh: Ed
- DobbinsCMA
15 May 2015 17:48
Ya idk never heard of them before. Bought the right ones today but don't fit the spark boots. I have some off my kz1000 build so I'll use those.
'80 Kz1000B4
KZ440 Project
81'KZ750E2 Project
Past- '81 Kz750H
KZ440 Project
81'KZ750E2 Project
Past- '81 Kz750H
- rstnick
15 May 2015 17:56
The plugs in your first picture have the little tops removed, they just screw on, and some caps wont fit with the little tops on the plugs.
I suspect your new plugs may need the tops removed to fit you spark plug caps.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- DobbinsCMA
15 May 2015 18:10
So they just screw off? Odd! Never knew you could do that.
'80 Kz1000B4
KZ440 Project
81'KZ750E2 Project
Past- '81 Kz750H
KZ440 Project
81'KZ750E2 Project
Past- '81 Kz750H
- rstnick
15 May 2015 18:15
Yes, may need a pair of pliers to get a good grip.
I have different spark plug wrenches to remove the plugs, and some have the rubber piece inside the socket.
You have to remove the little tops on the plugs to use these sockets.
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- DobbinsCMA
15 May 2015 18:36
Cool. Do they thread normally or reverse?
'80 Kz1000B4
KZ440 Project
81'KZ750E2 Project
Past- '81 Kz750H
KZ440 Project
81'KZ750E2 Project
Past- '81 Kz750H
- Richardb98
16 May 2015 17:01
I just picked up the same bike for 150! And I had to screw those tops off my plugs as well, they should screw off normally. BTW if you need any of the chrome bits I'll give you mine for the cost of shipping. I'm making a cafe racer so don't need them
- DobbinsCMA
24 May 2015 21:53
Here are some more pics. Love the brake fluid...paste.
Attachment image-11.jpg not found
Attachment image-12.jpg not found
Attachment image-13.jpg not found
Attachment image-14.jpg not found
Attachment image-15.jpg not found
'80 Kz1000B4
KZ440 Project
81'KZ750E2 Project
Past- '81 Kz750H
KZ440 Project
81'KZ750E2 Project
Past- '81 Kz750H
25 May 2015 06:54
Good grief! :sick: So the previous owner had never heard the phrase "routine maintenance"? Ed
- Randombeat
- 0 to 100 real quick...
25 May 2015 07:02
A little WD and that chain should be fine...
1980 KZ750H LTD-- pods-- vance & hines 4-1 --speedo/tach/blinker/switch deletes -- brat style
