GPZ750R1 -82 Will it be yet an other green Kwack 12 Aug 2019 07:31 #809062
  • scubaanders
  • scubaanders's Avatar Topic Author
  • Thank you received: 233
Tks Leon.
The project progress is at standstill over the summer, I had to use my time and carpenter skills to fight off a water leak and ant colony in my summer cabin :pinch: instead, but give it a few weeks and I will be back at it.
/Anders
Gpz750R1 1982
Gpz750A1 1983
Gpz1100A2 1984
FZ750 1985
Gpz900R -91
GPZ750R1 -82 Will it be yet an other green Kwack 15 Jun 2021 11:46 #850233
  • scubaanders
Guess you guys have given up on me, but she is alive. Last year I found out that the fork/wheel/brake setup that I had chosen didn’t really wanted to play together.
So it was back at the drawing board and in the end settled for a Zephyr 1100 fork utilizing the original steering steam, a ZR750 front wheel, ZRX400 brake disks and Tokico 4pots brake calipers from a GSX-R600. This off course meant that new headlight brackets had to be hammered out from a new sheet of aluminum and all the other tinkering that came with it.
But finally, last Saturday it was time for start up after trying to remember to tighten up all bolts and nuts.
She fired right up, the only snag was that I hadn’t tightened the petcock properly.
Sunday I was back in the workshop and retighten the cylinder head, fitting a horn and a reflex and It was time for the first test run. I headed out to the closest hotdog stand for lunch. On the way there she ran like a charm, so after stuffing myself with the culinary highlight a “Tunnbrödrulle” I thought what the heck, if she runs let see if she can take me the 50km from the workshop to my home and she did.
So today it was off to the MOT which is usually a bi yearly activity and she sailed through with flying colors and being +40 years old and with approved MOT under the belt she is now MOT exempted until 2099-12-31.
I still have some “pimping” to do, rebuild and repaint the vintage Öhlins, rebuild the front brake calipers, repaint clutch and generator cover, no biggies so its time to place the next victim on the bike lift.
 /A
Gpz750R1 1982
Gpz750A1 1983
Gpz1100A2 1984
FZ750 1985
Gpz900R -91
Last edit: by scubaanders.
GPZ750R1 -82 Will it be yet an other green Kwack 15 Jun 2021 12:26 #850237
  • ThatGPzGuy
  • ThatGPzGuy's Avatar
  • Thank you received: 376
Looks like a real performer. Nice job. I'm glad it turned out so well.
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
The following user(s) said Thank You: scubaanders
GPZ750R1 -82 Will it be yet an other green Kwack 15 Jun 2021 16:06 #850243
  • Skidmark
  • Skidmark's Avatar
  • Thank you received: 260
Sweet bike!  Great work....
Retired gearhead
'81 KZ-750 E2
'87 Suzuki Savage 650 Street Tracker
GPZ750R1 -82 Will it be yet an other green Kwack 15 Jun 2021 16:06 #850244
  • Skidmark
  • Skidmark's Avatar
Retired gearhead
'81 KZ-750 E2
GPZ750R1 -82 Will it be yet an other green Kwack 15 Jun 2021 21:10 #850256
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2051
Congratulations, Anders. Great job. Thanks for updating us.
GPZ750R1 -82 Will it be yet an other green Kwack 16 Jun 2021 03:02 #850259
  • 750 R1
  • 750 R1's Avatar
  • Thank you received: 394
Nice bike Anders...!!
GPZ750R1 -82 Will it be yet an other green Kwack 18 Jun 2021 18:20 #850387
  • rstnick
  • rstnick's Avatar
  • Thank you received: 373
Excellent job.
She's beautiful.
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
GPZ750R1 -82 Will it be yet an other green Kwack 20 Jun 2021 21:38 #850510
  • Daftrusty
  • Daftrusty's Avatar
  • Thank you received: 184
Fantastic work on a stunning bike!
Well done!
GPZ750R1 -82 Will it be yet an other green Kwack 20 Jul 2021 08:20 #852109
  • scubaanders
After some small issues that aroused during “shake-down”, steering neck that was not properly tightened, massive brake fluid leak from rear copper washers, things rubbing against each other. The stuff you expect, but now she purrs like a charm and runs like a frecking freight train.
Still needs some paint on the rims and the engine covers, a overhaul of the Zephyr 1100 fork and the GSX-R 600 front brake calipers then I will only enjoy it.
 So now, what’s next . . .
//A
Gpz750R1 1982
Gpz750A1 1983
Gpz1100A2 1984
FZ750 1985
Gpz900R -91
GPZ750R1 -82 Will it be yet an other green Kwack 21 Jul 2021 16:16 #852219
  • 750 R1
  • 750 R1's Avatar
Looking good Anders.  Your side stand looks good, did you modify anything to get it to stand up without too much lean, mine sits on a much more extreme angle, I'm thinking of removing the mount from the frame and repositioning it to get it ti sit straighter. I've seen lots of Kawasaki's that lean too far over on the side stand...
Email sent too mate...
GPZ750R1 -82 Will it be yet an other green Kwack 26 Jul 2021 06:19 #852564
  • scubaanders
Unfortunately I had forgotten all about the extreme sidestand lean angle when I prepareded the frame for paint. How I could have forgotten the close to death experience I had in a fast left hander on Falkeberg raceway back in the eighties when I hit the tarmac with the lump of sidestand mount and was close to end my racing career there and then.
But you are perfectly right Mike, that sidestand needs some kind of modification.
Back the I just cut the mount of with a angle grinder, but having a street bike without both center or side stands requires a constant supply of trees or houses when parking, something that limits the available parking options.
/A
Gpz750R1 1982
Gpz750A1 1983
Gpz1100A2 1984
FZ750 1985
Gpz900R -91
