Garage Queen - 1978 KZ650
- Dolby67
Re: Garage Queen - 1978 KZ650
06 Apr 2015 16:13
So....I finally got around to checking.
Pulled the plugs. No spark.
So what could have went wrong right in the middle of driving it that would make me loose spark?
- rstnick
07 Apr 2015 17:04
The main fuse still good?
Probably a bad connection somewhere.
You need to start testing with a multi meter (MM), or even a 12 volt light tester.
There is a red/yellow wire that feeds power to both coils.
Should get close to 12 volts there when checking with a MM, bike turned ON.
If not, then you will have to go backwards along that circuit and test again.
Should be a write up here somewhere, or in a Service Manual, how to check the ignition system.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
