1982 KZ1100-A2 Shaft Project
- jeffw
Re: 1982 KZ1100-A2 Shaft Project
30 Mar 2015 12:13
Well got her running and drug out of the basement w/ 4 people and some come-alongs and still was a little sketchy at that. Still running a bit lean but pretty close and will need a new valve cover gasket as it dripping pretty good if I run it for very long. Will post a video once I get the oil leak fixed and the carbs dialed in. It sounds similar to the 650 but definitely has a deeper sound and growl to it.
1977 KZ650 B1 "Cafed"
4-1 & Pods, Electronic Ig. & Dyna Coils
forums.kz650.info/index.php?topic=9020.0 - SOLD :(
1982 KZ1100 A2 Stripper
kzrider.com/forum/11-projects/596850-198...100-a2-shaft-project
The following user(s) said Thank You: Hoover
- Puffin
25 Sep 2015 00:19
This turned out really well Jeff
How does she ride ?
KZ1000 J Long Term Owner
KZ1100
KZ1100 Spectre project
KZ1100
- larriken
26 Sep 2015 21:45
Nice work mate, really like the tan seat and the white.
- jeffw
28 Sep 2015 11:41
Rides great and I am just finishing up a 1166cc build due to bad rings. I figured might as well go bigger if I am going to spend the money to refresh the cylinder anyways.
- wagonmaster69
- 78 KZ1000A2 / 82 KZ1100 Spectre
11 Nov 2015 08:47
Nice shafty.
I have a 82 Spectre and was wondering on you wiring specs and on the carbs what jets you use?
- Puffin
12 Nov 2015 06:56jeffw wrote: Rides great and I am just finishing up a 1166cc build due to bad rings. I figured might as well go bigger if I am going to spend the money to refresh the cylinder anyways.
Sounds like a great plan Jeff :lol: By the way where did you end up hiding that battery over the swingarm ?
KZ1100
KZ1100
- jeffw
31 Dec 2015 06:16
I ended up putting in the area just in front of the swingarm. As for wiring I used vehicleproducts.co.uk and used their 1mm wires, I think I spent like $40 for all the wiring I needed to rewire it and then used vintage connections for connectors and cws wiring for battery harnesses and LED turn signal relay. The jets are 137.5 Main & one up from stock on pilot jets whatever that is.
