1985 GPz750 Cafe Build
- CafeCruz
08 Dec 2014 18:19
So I picked this baby up and got straight to work...
Attachment IMG_0284.jpg not found
Attachment IMG_0286.jpg not found
Attachment IMG_0288.jpg not found
v
- CafeCruz
Re: 1985 GPz750 Cafe Build
08 Dec 2014 18:21
Breaking it down
Attachment IMG_0309_2014-12-09.jpg not found
Attachment IMG_0311_2014-12-09.jpg not found
Attachment IMG_0317.jpg not found
Attachment IMG_0330_2014-12-09.jpg not found
v
- CafeCruz
08 Dec 2014 18:23
I degreased the engine and threw on some new paint before I found the broken shifter bearing
Attachment IMG_0340_2014-12-09.jpg not found
Attachment IMG_0349_2014-12-09.jpg not found
Attachment IMG_0351.jpg not found
Attachment IMG_0352_2014-12-09.jpg not found
Attachment IMG_0353_2014-12-09.jpg not found
v
- CafeCruz
08 Dec 2014 18:25
i ordered a bunch of LED's, resistors and diodes to fab up my TRON style lights. I post details as the parts come.
![;) ;)](/media/kunena/emoticons/11.png)
v
- CafeCruz
08 Dec 2014 18:29
Over the weekend I de-tabbed the frame and lopped off the tail. My son's going to fab up the tail hoop in his shop class tomorrow! Free is good
Attachment IMG_0369_2014-12-09.jpg not found
Attachment IMG_0370_2014-12-09.jpg not found
Attachment IMG_0371_2014-12-09.jpg not found
Attachment IMG_0372.jpg not found
v
- CafeCruz
08 Dec 2014 18:31
So today, I stripped the tank, ground off the remaining paint/rust/bondo with the wire attachment and fired up the electrolysis bath...
Attachment IMG_0384.jpg not found
Attachment IMG_0385.jpg not found
Attachment IMG_0386.jpg not found
Attachment IMG_0387.jpg not found
Attachment IMG_0388.jpg not found
Attachment IMG_0389.jpg not found
v
The following user(s) said Thank You: tucsonKZ1kP
- CafeCruz
12 Dec 2014 16:48
After two days in the de-rusting, I am still seeing way too much rust in the tank. I may have to get a new one...
v
- CafeCruz
12 Dec 2014 16:52 - 12 Dec 2014 16:55
Did some work on the frame. Hit it with the wire brush on the grinder and then took the rest of the paint off with aircraft stripper. After a wash down with phosphoric acid she was ready for some self etching primer to stop surface rust. As I am not power coating, I will be using a tiny bit of bondo to smooth out an gouges in the frame from the de-tabbing...
Attachment IMG_0394.jpg not found
Attachment IMG_0398.jpg not found
v
Last edit: 12 Dec 2014 16:55 by CafeCruz.
- CafeCruz
12 Dec 2014 16:57 - 12 Dec 2014 16:58
Hoop time... Filled a steel tube with sand and wrapped it around a dolly wheel to get the shape. Thanks to my Har80* Fr8 welder, this was pretty straight forward. My first attempt at welding and I had a blast!
Attachment IMG_0420.jpg not found
Attachment IMG_0421.jpg not found
v
Last edit: 12 Dec 2014 16:58 by CafeCruz.
- CafeCruz
12 Dec 2014 17:00
Picked up a rearset and pegs from craigs... Ninja 250 stuff will work great after I fab up some new parts to mount them
Attachment IMG_0401.jpg not found
v
- CafeCruz
13 Dec 2014 15:32
Welded in the plates today. With the seat pan sitting on 1" spacer i will be able to mount all the electrics under here. Im going to fab a A123 lithium battery pack -- flat to accomodate in the space...
Attachment image.jpg not found
v
The following user(s) said Thank You: joe dirt
- fastdave
14 Dec 2014 03:35
Wow, it looks like your doing a nice job.
What kind of primer and paint did you use on the engine?
Also what kind of paint are you going to use on the frame?
What brand? Is it rattle can ?
I will be watching this build it is similar to mine.
![:) :)](/media/kunena/emoticons/8.png)
Faster is more fun
