My 82 KZ750 LTD
- dom2570
Re: Re:Re: My 82 KZ750 LTD
17 Oct 2014 12:27
I slapped some clubmans on her and have been riding non stop!
Whip it like a mule!
- dom2570
21 Oct 2014 12:12
Today, I noticed some smoke coming from my crankcase breather. Is this normal? The bike sat outside last night and was pretty wet this morning, my guess is condensation burning off.
I recently removed the emissions hoses are they were pretty much destroyed. Did an oil change (valvoline 10w40 motorcycle oil), and added the breather filter instead of having a wide open hose running down the side. I'm not sure if it has always had this faint smoke or I'm just noticing it due to the new breather.
- dom2570
Re: Re:My 82 KZ750 LTD
08 Jul 2015 14:46 - 08 Jul 2015 14:47
Checked the valves yesterday all in spec except the #4 intake. I cut down a suction cup to remove the bucket and it worked really well.
I decided to do the 530 chain conversation, ordered 16 and 38 sprockets and a JT chain. I got everything in the mail today except the rear.
Last edit: 08 Jul 2015 14:47 by dom2570.
- dom2570
11 Feb 2016 12:29 - 11 Feb 2016 12:30
I finished up a top end rebuild, then went through the electric system. Ditched the rear fender and added an led stop and turn signal strip.
Like most projects I keep coming up new ideas. I would like to make a new seat and get the electronics a bit more organized.
The PO drilled out the exhaust so I want to put a 4 to 1 on it. I like the delkevic exhaust but do not like the price on it so I am checking out other options.
During my research I found that a zr7 exhaust should be able to fit pretty easily. I found a few on ebay for about half the delkevic.
Does anyone else know of any other stocm 4 to 1 exhausts that might work?
Last edit: 11 Feb 2016 12:30 by dom2570.
- dom2570
15 Feb 2016 11:12
So far the bike has been running awesome. Unfortunately, I have found two leaky spots. The first is at the tach cable.
I think an oem cable will solve the problem. I got a cheap on from amazon and the leak started after that. I put a new o-ring on tach gear already. Still leaking.
The second is right at the base gasket. It is a very slight weep. Nothing major but I just put a new gasket on there and that really pisses me off. Not sure if that is worth ripping it apart again.
- dom2570
Last edit: 15 Feb 2016 11:15 by dom2570.
- djturnz
03 Mar 2016 05:43
For the base gasket leak, maybe re-check your torque values.
1982 KZ750 (4) LTD
