CSR1000 Project Build 07 Jun 2015 10:58 #675606
  • kaw-a-holic
  • kaw-a-holic's Avatar
  • Thank you received: 248
kaw-a-holic wrote: Davido,
I was doing some research for a Clutch Master Cylinder and notice the year of ZX9 you are using for parts has a MC reservoir attached to the lever. The angle that the MC reservoir was designed to sit on clubmans not on upright handle bars. This may cause air bubbles in the line. Just something to verify won't be an issue.
Correction, they were designed for clip-on not clubman. The drag bars may be alright as they would be close to the same angle.
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
CSR1000 Project Build 07 Jun 2015 11:02 #675608
  • kaw-a-holic
davido wrote: Hmmm! Ok,well something else to think about. I did buy straight bars (actually,I think i they were the first thing I bought on this project ,To kill the cruiser!!) but Ive also been having these strange perverted thoughts about clip ons!!! So Im not sure which way Im going to go. I have the straight bars,so Ill work with them for now.
So many details come up that you cant forsee everything. My attitude now is just to plow on . I noticed the gearchange rearset that I mounted is mighty close to the side stand. Is that Goin g to cause problems? No idea.Ill throw myself off that bridge when I come to it.
Onwards and upwards.
Yes, I have had the same conversation with myself. I decided I needed to get it up and running then doing some of the tweaks that aren't required. And then I saw your post on the hydraulic conversion and Had to do it too.
Jon
1977 KZ1000a1
Mesa, AZ
CSR1000 Project Build 07 Jun 2015 11:33 #675612
  • davido
  • davido's Avatar Topic Author
  • Thank you received: 286
Im sure other people have posted about it here but Im done trawling through the archive .Too many hours have been eaten up doing that already.If someone can point me to a specific build that would be great,otherwise Im just having a go at it. This is the build that inspired me;
www.badseeds.fr/construcbstwo.html
near the bottom of page 4.
Are you posting about yours? If you did,I could follow yours while you follow mine then neither of us could go wrong?!!?!
(Shops were closed today so I didnt get a hole drill.Ill get it tomorrow.)
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
CSR1000 Project Build 08 Jun 2015 10:44 #675730
  • davido
So,apparently 42mm is an odd size for a hole drill and nobody has it,so I went with a 41mm.
The hole was spot on centered
I sanded it out a bit and got a nice snug fit
How it meets up with the push rod
and itll sit something like this
so i will recut the profile on the front of the MDF before I transfer it to the alu plate
Thats it so far.
Something I forgot to mention,the main reason for using the MDF is to end up with a template.The plan being to cut the alu slightly oversize then run around it with the router to get a finished shape. So all the mistakes can be done on the first piece of MDF,then I make a second MDF plate, the good one, with all the holes drilled in the right place,the right profile to mate nicley with the block and nice clean ,sanded edges to run the router around. Then go for the final piece on the 10mm alu.
I havent tackled such thick aluminium before but the guy at the aluminium center reckons its no problem to use wood working bits.So long as I keep the piece cooled . A jigsaw for the rough cut then a copy bit on the router and lots of WD40.
We will see!
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
CSR1000 Project Build 08 Jun 2015 16:56 #675782
  • davido
Just lost out on a very nice Harris pipe on ebay.Whacked over the head in the last minute!! Consoled myself by ordering a pair of YSS shocks
The search for the 'Right' exhaust continues
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
CSR1000 Project Build 08 Jun 2015 17:21 #675787
  • kaw-a-holic
davido wrote: Im sure other people have posted about it here but Im done trawling through the archive .Too many hours have been eaten up doing that already.If someone can point me to a specific build that would be great,otherwise Im just having a go at it. This is the build that inspired me;
I will get some pics up. My Slave cylinder got lost in the mail. I need it to move ahead. Looking great on yours.
Jon
1977 KZ1000a1
Mesa, AZ
CSR1000 Project Build 08 Jun 2015 17:37 #675790
  • Randombeat
  • Randombeat's Avatar
  • 0 to 100 real quick...
  • Thank you received: 23
davido wrote: Just lost out on a very nice Harris pipe on ebay.Whacked over the head in the last minute!! Consoled myself by ordering a pair of YSS shocks
If you don't mind me asking, how much were those shox, and where from? They're gorgeous!
1980 KZ750H LTD-- pods-- vance & hines 4-1 --speedo/tach/blinker/switch deletes -- brat style
CSR1000 Project Build 08 Jun 2015 17:45 #675792
  • davido
No eBay APP ID and/or Cert ID defined in Kunena configurationThey are nice,arent they! I think theyre from Thailand but Im not sure. Theyve been getting very good reviews and are pretty popular among classic enthusiasts here in europe. The ones Im going for (those in the photo) are the cheapest model.
But they have others for different price range. The piggyback ones are very nice but out of my budget.
www.yss.co.th/index.php
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
CSR1000 Project Build 09 Jun 2015 03:02 #675826
  • Gordy
  • Gordy's Avatar
  • Thank you received: 5
I got a YSS shock for my Z650 and it seemed like the best option considering price, performance and reviews. I've not ridden it yet or had it for a while to say more than that yet. Also I've got a monoshock one so it's different to the dual shock options.
Pics of mine www.kzrider.com/forum/11-projects/593845...tyle?start=60#669842
CSR1000 Project Build 09 Jun 2015 11:27 #675887
  • davido
It was a toss up between theYSS and the Ikons but I couldnt find the Ikons I wanted and was told that it would take weeks to order them from down under.! They were a similar price and they werent Hagons, so I went with the YSS. Itll be a while before they hit the road though.A lot of other stuff to do first.
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
CSR1000 Project Build 13 Jun 2015 08:58 #676412
  • davido
Back to the clutch conversion. One of the bolt holes was munched up,so Ive filled it with liquid metal and plan to thread an insert into it.
The problem is,its in a very awkward place (of course) and I cant get the drill onto it. I bought and extra long one yesterday and if I pull the
generator cover off,I hope to be able to get at it. Could someone do me a favour and get out the verniers. I need to know how deep the hole should be. I dont want to drill through into the crankcase.
Its the hole at the end of my finger.Top left.
Thanks in advance
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
CSR1000 Project Build 13 Jun 2015 09:05 #676415
  • kaw-a-holic
Davido,
I'm at work for another 3 hours. If no one else chimes in I can measure mune. I have a 77 kz1000a1, not sure if they are the same.
Jon
1977 KZ1000a1
Mesa, AZ
