- Thank you received: 292
CSR1000 Project Build
- davido
The search for the 'Right' exhaust continues
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
- kaw-a-holic
- Thank you received: 249
I will get some pics up. My Slave cylinder got lost in the mail. I need it to move ahead. Looking great on yours.davido wrote: Im sure other people have posted about it here but Im done trawling through the archive .Too many hours have been eaten up doing that already.If someone can point me to a specific build that would be great,otherwise Im just having a go at it. This is the build that inspired me;
www.badseeds.fr/construcbstwo.html
near the bottom of page 4.
Are you posting about yours? If you did,I could follow yours while you follow mine then neither of us could go wrong?!!?!
(Shops were closed today so I didnt get a hole drill.Ill get it tomorrow.)
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
- Randombeat
- 0 to 100 real quick...
- Thank you received: 23
davido wrote: Just lost out on a very nice Harris pipe on ebay.Whacked over the head in the last minute!! Consoled myself by ordering a pair of YSS shocks
If you don't mind me asking, how much were those shox, and where from? They're gorgeous!
1980 KZ750H LTD-- pods-- vance & hines 4-1 --speedo/tach/blinker/switch deletes -- brat style
- davido
But they have others for different price range. The piggyback ones are very nice but out of my budget.
www.yss.co.th/index.php
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
- Gordy
Pics of mine www.kzrider.com/forum/11-projects/593845...tyle?start=60#669842
- davido
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
- davido
The problem is,its in a very awkward place (of course) and I cant get the drill onto it. I bought and extra long one yesterday and if I pull the
generator cover off,I hope to be able to get at it. Could someone do me a favour and get out the verniers. I need to know how deep the hole should be. I dont want to drill through into the crankcase.
Its the hole at the end of my finger.Top left.
Thanks in advance
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
- kaw-a-holic
I'm at work for another 3 hours. If no one else chimes in I can measure mune. I have a 77 kz1000a1, not sure if they are the same.
Jon
1977 KZ1000a1
Mesa, AZ
- davido
If the other (known) measurements add up with yours then it should be good enough.
Thanks
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
- kaw-a-holic
Jon
1977 KZ1000a1
Mesa, AZ
- davido
Plan B;
Can anyone else help out here?
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
- missionkz
Did the screw/bolt come out intact?
If yes, just the female threads in the casting are buggered up?
If no, you already got the broken screw/bolt out?
The hole is now filled with epoxy?
In each hole, you do not want to make the hole a little larger, tap and use next size up mm larger diameter screw/bolt?
You want to drill and tap the epoxy and left over aluminum with the same size tap and not cut into much of the aluminum casting, using the epoxy to repair threads?
Or you want to run a helicoil type insert in an overbored/tapped hole?
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
