- Thank you received: 292
CSR1000 Project Build
- davido
27 Mar 2015 13:27 #665423
by davido
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
Replied by davido on topic CSR1000 Project Build
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
- Thank you received: 797
30 Mar 2015 06:44 #665766
by 531blackbanshee
Replied by 531blackbanshee on topic CSR1000 Project Build
nice progress sir!
- davido
31 Mar 2015 11:19 #665934
by davido
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
Thanks Leon. Next thing is to get the tail light mounted. I bought a bit of 4mm alu plate to form a mount. I want to get the ZXR light tucked in nice and tidy.Ive also got to weld on something to fix the tailpiece down to the frame. Thatll be my weekend.
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
- davido
07 Apr 2015 12:51 #666973
by davido
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
A couple of tabs welded on to bolt the seat down to
I didnt have enough room to fit the tail light and mount ,nicely under the tailpiece ,so, I had to whack the back hoop off again and shorten it even more..Also I shifted the mounting plate from under the hoop to over the hoop so I can get the tail light tucked in with the minimum of gaps.Unfortunately,with all the grinding and welding,I really thinned the steel on the hoop in places to the extent that I was blowing holes in it as I tacked it up.
Off to my local friendly bike shop again,to get the damage assessed..The result was a 2mm steel plate welded over the bottom of the hoop.
That should keep it from getting too wobbley.
I think (hope)thats it now for the welding.The frame is as ready as its going to be.Tail light mount and the number plate mount are next. Ive got some alu plate downstairsand ,hopefully,I can get that sorted tomorrow.
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
- davido
08 Apr 2015 11:24 - 08 Apr 2015 11:32 #667125
by davido
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
Alu plate for the Tail light mount.
Knocked up a bendy machine
If I was to do it again,I would make a shallow cut on the inside of the bend to get a sharper 90 degree angle. They all came out a bit rounded. Live and learn.
Heres the bike as it stands now.The lower part of alu plate will be cut back and bent out to hold the number plate.
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
Last edit: 08 Apr 2015 11:32 by davido.
08 Apr 2015 11:44 #667129
by 531blackbanshee
oh yeah!
coming right along :evil: ,lookin good.
keep us posted,
keep us posted,
- davido
09 Apr 2015 06:02 #667235
by davido
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
09 Apr 2015 06:13 #667236
by 531blackbanshee
that worked out nicely! :evil:
- davido
14 Apr 2015 04:51 #667877
by davido
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
Well Im just playing here really.Im not sure what I want to do. The tail light mount didnt turn of as i expected but I thought It was ok and itll do.Now Im in 2 minds.Ive bought another piece of alu plate and I think Ill have another go at it.If I cut into it,opposite the bends,I should be able to get a sharper bend on it.I hope.
Also had a go at a making headlight mount.The original wont fit on the ZXR front
So I bought some pipe hangers from the local plumming shop
I bent some steel bar ,threaded the ends and welded a couple of washers into it
and came up with this
Dont know if iI like them or not.I think theyre a bit too big so I might trimm them down a bit and look again.
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
- davido
14 Apr 2015 04:54 - 14 Apr 2015 04:56 #667878
by davido
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
No eBay APP ID and/or Cert ID defined in Kunena configurationAlso,I went for it and ordered these;
with a complete set of seals etc.
No more pitted pistons and rusty seized calipers.
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
Last edit: 14 Apr 2015 04:56 by davido.
- davido
15 Apr 2015 09:04 #668047
by davido
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
OK,I couldnt live with the tail light hanger,so, I had another go
New on on the left,old one on the right
I cut a 1mm slot on the inside of the bends which made them sharper
It looks a lot cleaner alround now.
I also ordered some new brake hoses today.
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
15 Apr 2015 12:13 #668075
by 531blackbanshee
i hate having to redo stuff.
but i hate it worse if i don't !
then it just glares at me everytime i see it.
good job on the remake sir!
