I had to get this one
- Kidkawie
- I bleed premix
Re: I had to get this one
02 Jun 2014 07:04
Any updates?
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
- skooterbum4real
02 Jun 2014 16:39
Hey Kidkawie..... I haven't got to much done with the bike so far. I've replaced the plugs, and put a little oil in each cylinder. All four plugs were extremely hard to remove. I had to slowly work them back and forth, using some PBlaster to help. Then I had to run a thread restorer down each hole. I've done an oil and filter change too.
I've got an aftermarket ignition and key set, and a new throttle cable ready to install. I have to pull the carbs and go through them, then It might be ready to start. I hope all is well with the engine, whan I get it running.
This is going to be a long process for me. I'm a broken down old fart, and don't move to fast anymore.
1978 KZ650B 8,500 miles
1976 KZ750 Twin
SPECIAL CONSTRUCTION V-TWIN CHOP
1976 KZ750 Twin
- P21
02 Jun 2014 18:42
nice find!
looks to me to be Vetter fairing and the lowers good score sir!
Kawasaki KZ 1000 Police (2002) P21
The following user(s) said Thank You: skooterbum4real
- skooterbum4real
02 Jun 2014 23:23
Yes it is a Vetter fairing. It's the first full fairing I've seen that doesn't require the removal of the factory headlight. So it makes it even better, that it still has that headlight. I'm getting excited to get it running, to verify it has a good engine.
1976 KZ750 Twin
1976 KZ750 Twin
- John T
03 Jun 2014 01:54
$200.00
Wow
Congrats.
Wow
Congrats.
True Wisdom Only Comes From Pain.
- jmoney05
03 Jun 2014 04:08
Very nice, I had found a product called METAL RESCUE which works wonders at removing rust!
1978 Kz650D
- skooterbum4real
03 Jun 2014 13:51
Thanks guys !!
I will see if I can find the METAL RESCUE at one of my local stores, and give it a shot.
1976 KZ750 Twin
1976 KZ750 Twin
