Xt550 Build
  • Racewayelko
  • Racewayelko's Avatar Topic Author
Re: Xt550 Build
05 Apr 2014 22:03
#628017
i switched them back into place, no scarring on the cam or caps. they are now in order and torqued correctly, made a video but it is rendered useless by me switching the caps back, oh well will make a new one tomorrow.
Keep it rubber side down everyone :)
Klx 110, TTr125, TTr250, 1982 kz750-N1 (Spectre), Xt-350 (soon to be the new home of a Kz550 engine :) )
  • loudhvx
  • loudhvx's Avatar
Re: Xt550 Build
06 Apr 2014 08:59
#628049
For anyone else who may search this subject, ...
they are hard to see when the cams are in place, but there are numbers (1 - 8) cast into the head surface, under the cams, which correspond to the number on the cam cap. They are easy to see with a flashlight.
  • Racewayelko
Re: Xt550 Build
08 Apr 2014 10:04 - 08 Apr 2014 10:09
#628332
I will show the stamped part in a video (once I get the mounts figured out :) ) Drained the oil today circa 1994 (last time it ran) I only get an hour in class which sucks but I am slowly making progress. I get the dumbass of the day award though, I thought the engine would fit without modification and was sad when it wouldn't until my friend (Tom) pointed out that the exhaust studs were hitting the down tube so I took two nuts, butted them together and removed one of them just as the bell rung -_- oh well, will continue it on thursday when I get more time to work on it.
Oh and another name for it... I am absolutely in love with the new ktm superduke 1290, kinda want to call this project the superdukie :side:
Last edit: 08 Apr 2014 10:09 by Racewayelko. Reason: added info
  • Racewayelko
Re: Xt550 Build
24 Apr 2014 10:07 - 24 Apr 2014 10:09
#630216
Sorry it has been awhile since I posted, not much has gone on until the last few days. Got the braces cut and the frame bent. I have a plan to put a sub frame on around the motor that bolts on. I will give a more in depth update when I get time. Working 7 days having one off is taking it out of me on top of school. Attached is a photo of the motor inside the frame as it sits
Last edit: 24 Apr 2014 10:09 by Racewayelko. Reason: Site won't let me put photo on, will upload to flikr later
