1980 KZ550 build
  • Tusch
  • Tusch's Avatar
Re: 1980 KZ550 build
08 Mar 2014 16:40
#624555
Just took mine off again today. I work the plate off first and then lightly pry up on the back of the sprocket while turning it to apply even pressure.
Granted I could be doing in wrong
1983 GPZ550
  • ECrowther
  • ECrowther's Avatar Topic Author
08 Mar 2014 17:04
#624557
Do you mean the front piece because I try to turn it with the sprocket locked up but it still wont move.
  • loudhvx
  • loudhvx's Avatar
08 Mar 2014 19:10 - 08 Mar 2014 19:11
#624569
You just have to wiggle that little sheet metal plate off of the shaft. It has to be at the correct rotation so the teeth line up with the grooves on the shaft, to come off.
Then the sprocket just comes straight off.
Last edit: 08 Mar 2014 19:11 by loudhvx.
  • ECrowther
09 Mar 2014 17:10
#624647
Thanks for the advice I got the front sprocket right off B) . I started to spray paint the side covers and kawasaki logo and put the the chain on just to see how it looks and I think it looks really good. Will post pictures.
  • ECrowther
09 Mar 2014 17:11
#624648
The chain just on the bike
  • ECrowther
10 Mar 2014 10:05
#624713
Ok I have another question is the bike have a self oiler on it because the front sprocket is full of grease and dirt.
  • loudhvx
  • loudhvx's Avatar
10 Mar 2014 11:36 - 10 Mar 2014 11:38
#624719
No self oiler, but luckily, someone was oiling the chain. That puts less stress on the trans and motor if the chain is working correctly.
Modern, o-ring chains don't really need oiling. But they should occasionally get some o-ring specific chain spray on them to keep them from rusting. That will reduce sprocket wear as well.
If that's an o-ring chain you have, definitely don't use wd-40 on it. Get o-ring specific chain lube.
Last edit: 10 Mar 2014 11:38 by loudhvx.
  • ECrowther
14 Mar 2014 16:28
#625187
Alright guys sorry I haven't been on for awhile but no really new news besides that I found that the outside carb drain tube was broken. Do you know anywhere I could get a new one?
  • KZJOE900
  • KZJOE900's Avatar
  • Administrator
  • Administrator
    Super Users
14 Mar 2014 17:47
#625196
Do you mean the overflow tube? Post a picture to get some feedback. If cracked it can be soldered. If broken off you can replace it. I seem to remember Patton mentioning something about a replacement tube that can fit.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
  • ECrowther
14 Mar 2014 18:13
#625198
yea the overflow tube i don't have a photo on me but it is in two pieces it was broken off over over the top so i can but one piece on the nipple but that is it.
