My take on a KZ1000 Cafe
  • kawiman636
  • kawiman636's Avatar Topic Author
17 Feb 2014 01:28
#622516
Ok so heres what I have so far.
1980 KZ1000 frame
KZ1000 tank (80' or 82' not sure)
1982 KZ1000 motor
1982 KZ1000 Carbs with cone filters
2004 GSXR1000 swingarm (modified), wheel and brakes
2000 GSXR600 triple trees, fork, wheel and brakes
1-7/8" Dakota Digital Speedometer/Odometer
1-7/8" Dakota Digital Oil Temp Gauge
Shorai LFX19A4-BS12 which Im hoping has enough CCA since im new to lithium iron batteries
This is how she looks right now. I have mounted the front rotors since this picture
Attachment IMAG0654.jpg not found
Attachment IMAG0655_2014-02-17.jpg not found
This is how the GSXR1000 swingarm used to look before I modified it for a dual shock setup.
Attachment 936354_10151918895884937_611316864_n.jpg not found
This is one of the brackets I designed to mount the shocks. (The bolt isnt the final size, just didnt have the right size when I took this picture)
Attachment IMAG0659.jpg not found
I cut off the hole for the ignition on the GSXR600 upper triple tree and cut two 1-7/8" holes in it between the support ribs to mount my gauges in.
Attachment IMG_20140216_175019.jpg not found
I was tossing around ideas for steering stops and I am currently experimenting with the idea of using steering dampers as stops. I figure I will mount the body of them to the frame on both sides and mount the front end to the fork tubes using canabalized clip-on handlebars (recycling is cheap haha). This way I will get the advantages of the steering damper AND I will have steering stops. I will just mount the dampers so that they bottom out where I want the steering to stop.
Attachment IMG_20140216_174830.jpg not found
Attachment IMAG0680-1.jpg not found
I have never done anything like build a motorcycle before so I am learning as I go. Luckily im pretty creative and have a mechanical mindset. If anyone has any unique ideas throw them at me and let me know what you think of my project so far :)
Currently riding:2006 Kawasaki 636
Current project: 1980 Kawasaki KZ1000
  • kaw-a-holic
  • kaw-a-holic's Avatar
Re: My take on a KZ1000 Cafe
17 Feb 2014 03:39
#622519
Nice job so far. I'm a little concerned about how much material you have removed from the upper triple tree for the gauges. I hope it does not weaken it to much.
Nice job on the swinger shock mounts they look good.
As for steering stops, some guys just weld a longer strip of steel over the existing steering get stop tab that is already on the head tube.
Keep the pics coming!
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
  • ed spangler
  • ed spangler's Avatar
  • Tennessee Z
17 Feb 2014 04:35
#622521
kaw-a-holic wrote: Nice job so far. I'm a little concerned about how much material you have removed from the upper triple tree for the gauges. I hope it does not weaken it to much.
Very Nice! Looking very good so far! Good workmanship!
However......like kaw-a-holic.....I am concerned you may have removed way too much material from upper triple tree.
I also agree about his suggestion for steering stops.
Looking forward to more pics!
Have 1975 Kawasaki Z1-B & 2003 Harley Davidson Heritage Softail Classic
Had Hondas, Harleys and many ,many Z Series Kaws both Std. & LTD's
17 Feb 2014 05:38 - 17 Feb 2014 05:55
#622526
ed spangler wrote:
kaw-a-holic wrote: .... I'm a little concerned about how much material you have removed from the upper triple tree for the gauges. I hope it does not weaken it to much. ...!
However......like kaw-a-holic.....I am concerned you may have removed way too much material from upper triple tree....
There are lots of forces applied to the triple tree when a bike is ridden, especially when in turns, braking, hitting bumps, or coming down off a wheelie. You didn't leave nearly enough meat on that triple tree and it will eventually fail. :S When it does the rider is in for a very rude surprise and a trip to the ER!
Consider this - Suzuki GSXR-1000 bikes were recalled because their frames break near the headstock if a rider does wheelies. When this happens the front forks fall off. Those same forces that break frames can break a weakened triple tree.
I would toss that triple tree top, install a new one, and rethink the design. Ed
Attachment 00007_2014-02-17.jpg not found
Attachment 00008_2014-02-17.jpg not found
Attachment 00009_2014-02-17.jpg not found
Last edit: 17 Feb 2014 05:55 by 650ed.
  • sbc1320
  • sbc1320's Avatar
17 Feb 2014 05:39
#622527
Nice work. Does the 82 engine bolt into the 80 frame? I was thinking it doesn't from what I have seen on here.
1980 KZ1000 LTD-B4(MK II engine) - Progressive suspension, MTC pistons, Dynojet Stage III, all wear items replaced, WFO paint scheme(1978), etc..
Past bikes- 2 1976 Kz900's, 5 1975-76 Honda CB750's, Honda 500 -4, Honda 250, Honda 125, Honda 100, Suzuki RM 250, Honda XL350, Kawasaki KLR 650, etc..
  • ed spangler
  • Tennessee Z
17 Feb 2014 07:24
#622536
sbc1320 wrote: Nice work. Does the 82 engine bolt into the 80 frame? I was thinking it doesn't from what I have seen on here.
Excellent point!
I think 73-80 900-1000 will pretty much bolt in , I believe that after 1980 there were changes to Frame.
Check with 650ed !!...bet he'll know for sure.
Regards
  • kawiman636
17 Feb 2014 09:24
#622543
Here is a picture from the underside of the tripple tree. Figured id get all of your input on whether or not I took out too much material after you saw the bottom too.
I didnt cut into the support ribs at all. I drew red lines outlining where they are located. The 1-7/8" hole fit right between them.
Attachment IMAG0687.jpg not found
Like I said Im a newbie so I greatly value all of your insight. Im just hoping I dont have to scrap that triple tree and go with something different. If you still think I removed too much Ill have to go back to the drawing board. I would really like to keep the guages low profile like that though so how about one of these options: Make the whole upper triple tree solid aluminum (except for the gauge holes) so that there are no hollowed out areas like the stock one. OR have one made out of steel? In either case I could design it with some extra material thickness around the entire triple tree, increasing the wall thickness around the holes.
As far as the engine... I had bought the frame (1980 KZ1000) and then bought the motor from a different bike later. When I bought the motor the guy said it was a 1980 motor. I later realized some differences in the way it mounts to the frame. The 1982 has some motor mounts that are welded to the frame while the 1980 has motor mount brackets that bolt on. I have yet to try putting the motor in there, its been below zero here in Illinois, but I was hoping that the mounts would still line up. Sounds like I might be disappointed from what you are saying. Would that be something as simple as making new motor mount brackets or is it going to be a real pain?
Thank you guys so much for your feedback. Im trying to make this thing really unique which unfortunately means a lot of trial and error lol.
  • kawiman636
17 Feb 2014 09:38 - 17 Feb 2014 09:43
#622545
Thanks 650ed! What do you think about having that upper triple tree made out of steel? If I can Id really love to keep the gauges flush mounted.
Btw those pictures are scary as hell!
Last edit: 17 Feb 2014 09:43 by kawiman636.
  • wireman
  • wireman's Avatar
17 Feb 2014 20:24
#622621
Excellent point!
Regards
81 and newer used differant/extea front mountinf points.
  • kawiman636
17 Feb 2014 22:23
#622630
wireman wrote:
Excellent point!
Regards
So the back mounting points are the same? So would I be able to set it in the fame, bracing it up, mount the back points, and measure/fabricate some brackets for the front? Would that be a pain in the butt?
  • LarryC
  • LarryC's Avatar
18 Feb 2014 12:10 - 18 Feb 2014 12:26
#622679
From the picture, I don't see any worries with that top tree. The bulk of generated forces will be carried by the lower tree, through the stem, into the frame. Cutting the little nubs off where gauges mounted isn't going to make them weaker.
Take a good close look at some of the modern sport bikes. In particular, look at the little aluminum tangs welded to the frame where the top of the rear shock mounts. They don't look like they'd hold up...but they do.
When I was building my bike, I looked over the new bikes very carefully before I decided what approach I was going to take putting ZX7 suspension on an old KZ frame. Ultimately, it all worked out fine and the bike went down the road perfectly straight and handled excellent.
I milled 5mm off the bottom of the big, fat boss there the stem goes through to get more fork length and added some aluminum plates under the top clamp when I put traditional style bar mounts on it for drag bars.
I think you're doing a fine job. You want to pay careful attention to your trail measurement. Make dam sure you do measure it too. Get it right and the bike will be a joy to ride. Get it wrong and it could be a twitchy, dangerous, devil.... :)
Here's the one I did
Attachment leftside1comp.jpg_thumb_2014-02-18.jpg not found
Better shot of suspension
Larry C.
Last edit: 18 Feb 2014 12:26 by LarryC.
18 Feb 2014 12:19
#622680
LarryC wrote:
......From the picture, I don't see any worries with that top tree. The bulk of generated forces will be carried by the lower tree, through the stem, into the frame. Cutting the little nubs off where gauges mounted isn't going to make them weaker.........
Cutting the little gauge nubs isn't what would concern me. But boring those huge holes in the tree where there is no re-enforcement like there is where the fork tubes pass through scares the heck outta me. I wouldn't trust it at all. Ed
