1973 Z1 900
  • adsVA83
  • adsVA83's Avatar Topic Author
Re: 1973 Z1 900
22 Aug 2013 11:54
#602621
I will more than likely just go the route of using correct used parts that I can find, and only use aftermarket parts where they're absolutely needed like you said. I do plan on riding it, so i don't see why making it brand new showroom condition would be smart. I'm aware from doing a CB750 restoration, that there are little things such as the bolts (having the "8" on the head of them) actually make a difference to someone who knows what the heck they're looking at.
I do have both side covers and both are in good condition. I don't believe they have the correct emblems on them though. The center stand is not on the bike either, that's another item i'll need.
Re: 1973 Z1 900
22 Aug 2013 12:20
#602624
Consider the following........
www.z1enterprises.com/ItemDetails.aspx?i...ange&item=PM82-36010
OR
www.z1enterprises.com/ItemDetails.aspx?i...llow&item=PM82-36020
PLUS
www.z1enterprises.com/ItemDetails.aspx?i...1+H2&item=EM43-61010
PLUS
www.z1enterprises.com/ItemDetails.aspx?i...System&item=PM86-260
Then add nice repro badges (about $160 for all) plus other items (i.e. air box, etc.) to return it to stock appearance, and for about $3000 you'll have a bike that will make heads snap around to see your bike and you can ride ride it without feeling like a tiny scratch will stop the world from turning. Ed
  • KZJOE900
  • KZJOE900's Avatar
  • Administrator
  • Administrator
    Super Users
Re: 1973 Z1 900
22 Aug 2013 13:00
#602630
Would like to add, if you are not aware already, the 29 mm smooth bores are worth about $500 to $700 by themselves. I suppose you could sell them and get original 28's, just depends on your preferences. I would keep them myself. I doubt very much it would take anything away from the resale.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
  • adsVA83
Re: 1973 Z1 900
22 Aug 2013 14:18
#602647
All those links are great, I didn't even realize you could still get some of that stuff, albeit reproduction it doesn't bother me. I will keep the original body work in case I sell and someone wants it to be painted. I actually have 2 sets of newly painted CB8750 body work that should sell for close to the amount of the Z1 stuff.
I noticed the 29mm smoothbores were worth quite a bit, i'll probably just leave them on there. If someone is hung up on having the original 28mm ones, I can cross that bridge and find a set at that point.
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
Re: 1973 Z1 900
22 Aug 2013 14:47
#602648
...and, if you are so inclined, you could join kawasaki-z-classik.com and really get involved in the restoration of your Z1!
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
