Started a new budget cafe build 79 750
- wcysl
Re: Started a new budget cafe build 79 750
29 Aug 2013 13:05 - 29 Aug 2013 13:15The engine was very badly oxidized. I used a foaming degreaser a small brass and small stainless steel wire brush, along with a sanding pad. It took some time to thoroughly clean and prep the surface.Topper wrote: The engine paint looks like it came out great. Can you share any photos/details about your engine painting process?
I used off the shelf VHT engine enamel. I started with their light gray color. Using very light coats. Finished with their cast Iron color. The reason I used the light gray to coat everything, was to make all areas more visible. As I covered with the darker paint I knew if I was missing or not getting even coverage.
I can say (thanks to a leaking petcock...now replaced, that the paint does okay at resisting gas spilled on it.ere
Gas poured down the side of the engine.
I can tell you that the engine enamel resists gas and oil far better than their 2000 degree header exhaust paint :whistle: tried that on another bike.
Ahh the sound of a socket wrench late at night. haha..
1979 KZ1000 B3
1978 KZ650 C2 $500 Barn find!
1978 KZ400 B1 Free, Saved from scrap!
1979 KZ1000 B3
Last edit: 29 Aug 2013 13:15 by wcysl.
- wcysl
29 Aug 2013 13:09 - 29 Aug 2013 13:09
Oh and after I scrubbed the engine, I washed it, let it dry, then used clean rags and alcohol to prep just prior to paint.
1979 KZ1000 B3
1979 KZ1000 B3
Last edit: 29 Aug 2013 13:09 by wcysl.
- Topper
29 Aug 2013 17:08
Thanks! Your photos never show the engine out of the bike, but I'm assuming you had them apart and tore down the engine?
Permanent and perpetual noob.
1979 KZ750 Twin
2009 Kawasaki Versys
1979 KZ750 Twin
