KZ 900 new school old school Project
  • Landfair
  • Landfair's Avatar Topic Author
19 Mar 2013 14:21 - 19 Mar 2013 14:22
#577698
Here is my project I recently started. I bought a box of parts from a kz900 a 1000 frame and zx11c front and rear end. To start I decided to do the triple tree swap and the swingarm because I figured those would give me the most trouble. So for the steering stem on the zx11 it had already been turned down to fit the lower stock Kz bearing. Then I made a sleeve to fit the top of the zx11 stem and the ID of the stock Kz bearing.
06 Ninja 650r
76 kz900 motor and parts 80 kz1000 frame (project)
Ktm 520 supermoto
01 katana (for sale)
Last edit: 19 Mar 2013 14:22 by Landfair.
  • Landfair
Re: KZ 900 new school old school Project
19 Mar 2013 14:25
#577700
Next I decided to buy a stock kz swingarm and extend it myself. I cut it and lathed out two 6 inch extentions that widened the rear to 10.5" wide to allow for the zx11 rear rim. Originally it was only 9" wide I havent got around to welding it yet but will post more pics when done.
06 Ninja 650r
Ktm 520 supermoto
  • Landfair
19 Mar 2013 14:29
#577701
I got anxious on the wheels because I had heard of different ways of polishing the lips on wheels. I had heard to use aircraft stripper and let it sit for a day til it came off and i had heard of sanding. After trying both methods I decided both took way to long. I found that if you use a Scotch Bright pad (more like 6 lol) and the air craft stripper it takes the powdercoat off fairly easily. Polish them a bunch and they end up looking great!
06 Ninja 650r
Ktm 520 supermoto
  • mopguy
  • mopguy's Avatar
19 Mar 2013 14:51
#577704
I like what I've seen so far, keep up the good work.
The following user(s) said Thank You: Landfair
  • lazy5892
  • lazy5892's Avatar
19 Mar 2013 15:12
#577708
Looking good so far man! Cant wait to see the rest
  • Landfair
20 Mar 2013 17:47
#577879
Here is a mock up i did before I actually started working on the bike. I just set all the stuff on it loosely.
06 Ninja 650r
Ktm 520 supermoto
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
20 Mar 2013 18:03
#577881
i like the vision :evil: !
keep us posted,
  • Haybus
  • Haybus's Avatar
  • Big Al
20 Mar 2013 21:50
#577909
Looks cool. 6" is a lot to add to a swingarm that wasn't all that stout to begin with. Have you considered adding some bracing? How about extending the inner flange of the extension further into the original legs? Doesn't look like a lot of engagement in the pic.
1976 KZ900 LTD (sort of)
2005 FJR
2009 Hayabusa
www.kzrider.com/forum/11-projects/557845...-streetfighter-build
  • Landfair
20 Mar 2013 22:36
#577916
Thanks for the input and yes I have considered that. I am debating on putting another tube in and plug welding it. There is only a 3/4 an inch or so flange. However I work with proffessional welders in the summer that can put on a very thick weld. I will let them look at it and see what they think....(originally I was going to have an inch and a half on each side but ran out of bar :ohmy: )
06 Ninja 650r
Ktm 520 supermoto
  • Charles Nix
  • Charles Nix's Avatar
  • 1981 kz 1000c4
20 Mar 2013 23:22
#577919
Sweet ,vey sweet looking bike!
  • Landfair
04 Apr 2013 18:42
#580578
I got the swingarm welded and didnt like the fitment so im going to redo it sorry I forgot to take pictures. I also decided how i was going to hook up my stabalizer. However most of my weekend went to finishing my ninja 650r so I had something to ride this summer tho :woohoo:
06 Ninja 650r
Ktm 520 supermoto
  • 531blackbanshee
  • Vendor
  • Vendor
05 Apr 2013 10:03 - 05 Apr 2013 10:03
#580678
cool lookin ninja you have there sir.
it looks like a ton of fun to ride.
Last edit: 05 Apr 2013 10:03 by 531blackbanshee.
