HollywoodMX's Drouin Supercharged 77 KZ1000!!
  • Hollywoodmx
  • Hollywoodmx's Avatar Topic Author
Re: HollywoodMX's Drouin Supercharged 77 KZ1000!!
13 Jan 2013 14:06
#567151
bluezbike wrote: That's going to look so sweet, I especially like the proportions of the bigger head fins next to the S-charger
Ya I think I'm going to square them off a bit make it more race looking than cruiser.
- 82 GPz1100injection
- 77 Kz1075 Supercharged
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
  • Hollywoodmx
13 Jan 2013 14:06 - 14 Jan 2013 00:39
#567152
Edit: Struggling to get the kz steering stem out of the lower triple.
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
Last edit: 14 Jan 2013 00:39 by Hollywoodmx.
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
14 Jan 2013 10:55
#567311
heat is your friend when trying to remove the stock stem.
  • StreetfighterKz
  • StreetfighterKz's Avatar
  • Away
14 Jan 2013 13:32
#567323
What I had done with I swapped a newer Gsxr600 front end into my 900 was countersink the stem into the lower triple about an 1/8" or so. That allowed me to make the stem "longer". It might be worth a shot...
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
  • Hollywoodmx
15 Jan 2013 12:33 - 15 Jan 2013 12:33
#567461
StreetfighterKz wrote: What I had done with I swapped a newer Gsxr600 front end into my 900 was countersink the stem into the lower triple about an 1/8" or so. That allowed me to make the stem "longer". It might be worth a shot...
Later, Doug
Ya I did the measurements and I have two choices.
- Counter sink the R1 stem 1/4" up the in the lower tree which will allow the top kz seat normally while being able to use the lock nuts. I would also need to reduce the lower bearing area OD of the stem to match the lower kz bearing ID. I would then weld the stem in the bottom if possible.
- Swap out KZ stem and use a bushing byboring and cutting the R1 stem. (Leon's trick).
P.S. Still waiting on the rear wheel to come in which is holding up my swingarm modding.
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
Last edit: 15 Jan 2013 12:33 by Hollywoodmx.
  • Hollywoodmx
19 Jan 2013 23:04 - 19 Jan 2013 23:26
#568231
Got the steering stem out! After getting the weld fully removed I just put a socket on it and whap, whap! It came out. :)
Also worked on the cooling fins. I wanted to make them more normal and less cruiser looking while retaining as much metal as I could. This is the before.
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
Last edit: 19 Jan 2013 23:26 by Hollywoodmx.
  • Hollywoodmx
19 Jan 2013 23:08 - 19 Jan 2013 23:21
#568232
This is the after. Although it looks like a simple change it took over 4 hours using all kinds of tools and lots of filing because after any grinding or hard filing you have to get rid of the stacked/blobbed metal on both the top and bottom of the fins. Then I had to match up both side so they were even. It ended up being a lot of hand work.
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
Last edit: 19 Jan 2013 23:21 by Hollywoodmx.
  • 531blackbanshee
  • Vendor
  • Vendor
20 Jan 2013 23:15
#568401
much better,
i wasn't feeling the whole handlebar mustache thing :P .
keep us posted,
  • bluezbike
  • bluezbike's Avatar
20 Jan 2013 23:55
#568414
That does look much better, fits in nicely with the Supercharger
79 KZ 1000 LTD
  • wireman
  • wireman's Avatar
20 Jan 2013 23:56
#568415
Much better,it always reminded me of Ronald mcdonalds cop sidekick before! :woohoo:
Attachment il_fullxfull_368705121_vox5.jpg not found
  • Hollywoodmx
22 Jan 2013 01:48
#568603
Haha! :laugh:
Ya never sat with me well either, right up there with gold... it still blows my mind its 24k gold and I have to paint on top of it.
I can square the fins even more if you guys think it would look better but I would lose a lot more material in doing so which defeats the goal of the fins somewhat.
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
  • 531blackbanshee
  • Vendor
  • Vendor
22 Jan 2013 10:38
#568635
i could live with the way you have them now.
you can always trim em later if you ride it for awhile and want to .
