HollywoodMX's Drouin Supercharged 77 KZ1000!!
  • Hollywoodmx
  • Hollywoodmx's Avatar Topic Author
Re: HollywoodMX's Drouin Supercharged 77 KZ1000!!
02 Sep 2013 02:35 - 02 Sep 2013 02:37
#604396
Well she runs not long enough for a video though.
I made a custom bracket for the fuel system and got it all setup in its new location. Exhaust is on. I actually like
I got the wiring hooked up enough for it to run. It struggled to start and I was scratching my head. It seemed I wasn't getting fuel, yet my fuel pressure gauge was showing 3 psi. I printed a wiring diagram, scratched head, checked for spark. I started to think it was the carb bowl. I shot some gas in the carb and VROOOM! It scared the shit out of me as I forgot how loud the bike is! lol.
I disassembled the carb (which was spick and span from my previous cleaning) and the float needle was sticking. The test for that is blow in the "fuel in" of the carb and move the bowl up and down. Air should stop when you push the float up. In my case it was getting stuck in the up and down transition which I knew something was wrong. So I sanded/cleaned the float needle with a little scotch brite pad and then a splash of wd40. All good.
Hooked it all back up and VRROOM! The jetting is all messed up so I have to dial it in to idle properly. I forget what the fuel regulator was supposed to be set at, I think it might be in one of my pages here.. I had to stop as it was getting late and the bike sounds like a day at the race track; but in my garage..lol. :lol:
I feel pretty good though as I got lots done this weekend.
P.S. My steering doest swing enough as I quickly learned moving it in the garage, which will mean more custom work on the upper and lower trees.
Attachment 20130901_140802.jpg not found
Attachment 20130901_143626.jpg not found
Attachment 20130901_140810.jpg not found
Attachment 20130901_182408.jpg not found
Attachment 20130901_182347.jpg not found
Attachment 20130901_182358.jpg not found
Attachment 20130901_182318.jpg not found
- 82 GPz1100injection
- 77 Kz1075 Supercharged
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
Last edit: 02 Sep 2013 02:37 by Hollywoodmx.
  • turboking
  • turboking's Avatar
14 Sep 2013 15:34
#606414
QUOTE: I have these extra 2 parts that I have no idea what they are for?? They are threaded bungs..any idea's?
the 2 lugs are to be welded to the frame in front of the swing arm pivot to support the outboard bearing support, ties it all together...... makes it stronger :huh:
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
  • T_Dub
  • T_Dub's Avatar
14 Sep 2013 15:46
#606417
I'm digging the build, if not the colours. But who am I to talk, my bike had a blue frame and wheels at one time haha. Keep it comin!
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
  • Hollywoodmx
14 Sep 2013 20:06 - 14 Sep 2013 20:09
#606435
turboking wrote: QUOTE: I have these extra 2 parts that I have no idea what they are for?? They are threaded bungs..any idea's?
Awesome, thanks!! That makes sense, except they don't drill the holes for those bolts to make it more plug and play, likely because of the welding not going to be 100% exact. Except if the holes were drilled then you could bolt the bungs and tack them on the frame with everything in place. In the end between that, no directions, and the bit of interference on the foot pegs I'm disappointed. It's too bad because a nice piece and the clutch cable mount is ingenious (took me over an hour to figure that's what it was for) and the price is reasonable.
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
Last edit: 14 Sep 2013 20:09 by Hollywoodmx.
  • Hollywoodmx
14 Sep 2013 20:12 - 14 Sep 2013 20:14
#606437
Every body likes video right?
Fixed the major idle surging problems I had before vacation.. I feel pretty smart about finding the issue; I had to vent my ghetto fabulous gas tank! :P
Engine is just shy of cold:
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
Last edit: 14 Sep 2013 20:14 by Hollywoodmx.
  • turboking
15 Sep 2013 08:54
#606498
no pre drilled location holes :blink: still you are welcome..... :woohoo: keep up the great work B)
1985 GS 1150E
1983 GS 1100E
  • Hollywoodmx
15 Sep 2013 16:32
#606545
While I made good progress recently, the amount of new set backs is discouraging though. Lower trips are hitting the oil cooler (just noticed. I adjusted the gas tank further back for more clearance now the head light mounts are hitting the gas tank. Steering stops are not giving me enough radius either.
Overall I think I need the custom trips ($$$!!) sooner than I thought. Ones that move the r1 forks forward more (like the stock setup) for overall clearance gains everywhere.
New rear sets are not 100% bolt on and will require modification to support the rear master cylinder and I will need to fab up some delrin bushings to support the rear sets in the rear. Shifter needs a custom rod, and I will have to get a custom kick stand made as it is hitting the rear set rod and too close to the shift leaver. Lastly rear set pre-mounts I got made will need custom back plates.
I did get the rear wiring tidied up but I'm not happy with it, I want it under the seat which is an annoying job.
Overall I don't think I can get it on the street for fall with what is ahead of me so I am thinking of switching gears and working on my TR-1 build as it requires much less work to get on the road for fall.
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
  • K.D. HART
  • K.D. HART's Avatar
19 Sep 2013 21:00
#607110
Hollywoodmx wrote: Every body likes video right?
I like what you have done so far. Very nice! :woohoo:
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
20 Sep 2013 09:42
#607143
the thing sounds mean as he!! :evil: !!!!!!!!!!
  • Hollywoodmx
01 Nov 2013 19:05 - 01 Nov 2013 19:07
#611863
A little update. Changing focus to my TR1 has provided some benefits. I'm actually fairly close to completing the kz! I'm In talks with Les for custom trips and rear sets. Once That is all wrapped up and in my hands I will switch gears to the KZ to finish it.
1. It allows me to do a mind reset.
2. In my TR1 I build I rebuilt the harness and learned a lot of good things for when I do it to the kz. The yamaha is a lot more difficult than the kawi If you have experience with the old Yamaha electrical you know what I mean.
3. The shop tools increased. Bought a bench sander. Welder and new paint products. All these things make bike building so much easier. I cant believe I used to file by hand...lol.
Oh I forgot.. Z1r fron fairing on its way. B)
Attachment f1.jpg not found
New Lincoln 140 welder. Even at 120v it blow through a hole in fairly think metal with ease.
Attachment 20131013_164025.jpg not found
Iwata lph80 mini paint gun with Iwata regulator.
Attachment 20131024_190326.jpg not found
3m PPS system for both my new and old gun. I keep buying paint with hardener (iso's) so I figure I will up my personal safety and speed of my painting clean-up.
Attachment 20131101_181011_HDR.jpg not found
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
Last edit: 01 Nov 2013 19:07 by Hollywoodmx.
  • Hollywoodmx
01 Nov 2013 19:40
#611866
Yay welder! Can make subframes now!
Attachment 20130929_172854_HDR.jpg not found
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
  • Haybus
  • Haybus's Avatar
  • Big Al
01 Nov 2013 20:39
#611870
Wait, what bike is that? Focus, we need that KZ in all it's awesome super charged glory running stat!!
Alan
1976 KZ900 LTD (sort of)
2005 FJR
2009 Hayabusa
www.kzrider.com/forum/11-projects/557845...-streetfighter-build
