HollywoodMX's Drouin Supercharged 77 KZ1000!!
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
Re: HollywoodMX's Drouin Supercharged 77 KZ1000!!
11 Mar 2013 15:28
#576520
a lil bit closer :evil:!!!!!!!!!!!
  • Hollywoodmx
  • Hollywoodmx's Avatar Topic Author
11 Mar 2013 23:48 - 12 Mar 2013 00:15
#576599
531blackbanshee wrote: a lil bit closer :evil:!!!!!!!!!!!
Wait till you see this! You're gonna love it..
There are a few people who have been less pleased with some of my decisions, some might change your minds after I show this next series of pic posts.. I had some hesitations with the R1 stuff due to the large rear and some of the integrations constraints. Now after witnessing the bike in real life with the set-up, I am super happy as it looks super bad ass as it has a bit of a drag look to it. :evil: :evil:
Attachment 20130310_151359.jpg not found
Attachment 20130310_151405.jpg not found
Attachment 20130310_151411.jpg not found
Attachment 20130310_151416.jpg not found
Attachment 20130310_151426.jpg not found
Attachment 20130310_151440.jpg not found
Attachment 20130310_151457.jpg not found
Attachment 20130310_151504.jpg not found
- 82 GPz1100injection
- 77 Kz1075 Supercharged
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
Last edit: 12 Mar 2013 00:15 by Hollywoodmx.
  • Hollywoodmx
11 Mar 2013 23:55 - 11 Mar 2013 23:59
#576600
Continuing the awesomeness.
Attachment 20130310_151512.jpg not found
Attachment 20130310_151520.jpg not found
Attachment 20130310_151531.jpg not found
Attachment 20130310_151541.jpg not found
Attachment 20130310_151551.jpg not found
Attachment 20130310_151551_2013-03-11.jpg not found
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
Last edit: 11 Mar 2013 23:59 by Hollywoodmx.
  • Hollywoodmx
12 Mar 2013 00:06 - 12 Mar 2013 00:08
#576604
Continuing the awesomeness part deux..
Attachment 20130310_154753.jpg not found
Attachment 20130310_154800.jpg not found
Attachment 20130310_154900.jpg not found
Attachment 20130310_154907.jpg not found
Attachment 20130310_155140.jpg not found
Attachment 20130310_154816.jpg not found
Attachment 20130310_154941.jpg not found
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
Last edit: 12 Mar 2013 00:08 by Hollywoodmx.
  • Haybus
  • Haybus's Avatar
  • Big Al
12 Mar 2013 00:29
#576610
Love the stance, long and low. Front fender is perfect. Not a huge fan of the rear though. I'm partial to the KZ boat tail. It really ties the room together.
Alan
1976 KZ900 LTD (sort of)
2005 FJR
2009 Hayabusa
www.kzrider.com/forum/11-projects/557845...-streetfighter-build
  • Hollywoodmx
12 Mar 2013 01:20
#576615
Now it's not all cup cakes and sunshine; few problems and a lot of :pinch: going on..lol.
Any suggestions appreciated.
1. R1 upper trip hits the gas tank well before the steering stops do. I think I need a custom upper triple now.. :( I guess if I need a custom one I will make it raise the forks.
2. The steering stops need to modified in the lower trip as well as there isn't enough rotating. I was going to see if I can grind enough away otherwise they have to go and I'm going to have to cut them off and drill and tap holes for bolts to do the stopping. More work... :pinch:
3. Because of my larger oil pan which then means lower exhaust I think the bike might be too low to the ground now.. It sits quite a bit lower now.. This I will have to test later to verify but I think it's extremely likely.. :pinch:
4. One the bimota fender looks quite a bit better than the R1 fender but requires a custom mount which in the end = more work. I think what I might do is attempt to basterdize the R1 to the point of no return to see if I can get it to look good enough to roll with which I think will take me less time than fabing an aluminium piece. :pinch:
Trip hitting the tank.
Attachment 20130310_154824.jpg not found
BIMOTA FENDER
Attachment 20130310_155835.jpg not found
R1 FENDER
Attachment 20130310_155145.jpg not found
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
  • bluezbike
  • bluezbike's Avatar
12 Mar 2013 03:53
#576635
Tons of really cool fab work Hollywood. This is just my personal opinion....I prefer the Bimota fender as it is a little "quieter". I believe you should let that AWESOME motor do all the talking!! In appearance as well as on the street where it matters! The other thing you might want to try is to reverse the front fender making the body work appear a little longer. Is there any way you can bring the tank back a bit to help clear the triple? The lower part of the tail section is a little too dominant to my eye but I like the square upswing behind the seat...bit like a rear spoiler....The wheels and rear swingarm are spot on and I think you have the amount of stretch right on the money, I also like the black forks. Such a cool looking bike!!!
79 KZ 1000 LTD
  • Hollywoodmx
12 Mar 2013 04:50 - 12 Mar 2013 04:51
#576640
bluezbike wrote: Tons of really cool fab work Hollywood. This is just my personal opinion....I prefer the Bimota fender as it is a little "quieter". I believe you should let that AWESOME motor do all the talking!! In appearance as well as on the street where it matters! The other thing you might want to try is to reverse the front fender making the body work appear a little longer. Is there any way you can bring the tank back a bit to help clear the triple? The lower part of the tail section is a little too dominant to my eye but I like the square upswing behind the seat...bit like a rear spoiler....The wheels and rear swingarm are spot on and I think you have the amount of stretch right on the money, I also like the black forks. Such a cool looking bike!!!
Thanks mang! Ya I'm really digging the slight stretch too. :)
I like the bimota fender too but I will try this idea to make the R1 fender look more plain (I'm thinking I will probably wreck it trying though)..lol
Ya I test fitted the bimota tank with the KZ suspension and it was fine so the issue is specific to the R1 front. I can move the tank its made for the kz frame so it has the same stops as the stock tank. I "could" take off the rubber grommets off the frame see if it makes a difference but I wouldn't want to run without them.
Ya the bimota rear is a unique one, not everyone's fav that's for sure. I have a H2 rear fairing kicking around but it doesn't look right with the bimota tank. Funny enough the bimota looks more natural...lol.
Here is a pic with it painted and the tail light, to me it looks more normal that way. If you look closely this person chopped the length on the rear fender to basically leave a little after the licence plate and that's it. If you look at mine there is a good several inches more of a drop hang part.
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
Last edit: 12 Mar 2013 04:51 by Hollywoodmx.
  • kzz1king
  • kzz1king's Avatar
12 Mar 2013 09:01
#576651
Good luck sorting out the issues. The paint job really changes the look of the tail! With the right paint combo it will look great. Looking good.
Wayne
Home built KZ1000 turbo setup
  • bluezbike
12 Mar 2013 16:07
#576693
I agree with Wayne that the paint will be a big factor on your bike. I notice on the red Bimota that the seat is a lot shorter than yours and the tank is slimmer (vertically) and I think it helps with the proportions.....in fact I think it's going to be a game of millimeters to get it "right". One good idea is to use black electrical tape to cover or tape off lines on the body panels you have as it is really easy to re-position again and again till it feels right. Really cool stuff!! This bike is gonna rock hard :evil: :evil: :evil:
79 KZ 1000 LTD
  • Hollywoodmx
13 Mar 2013 02:08 - 13 Mar 2013 02:22
#576770
Thanks guys. I think the tank and seat size differences are an optical illusion. The vintage pic tank looks lower only because normally the kz upper trip sits over the tank but on my r1 triple it sits lower making it seem taller. The rear fender looks smaller cause it has been chopped at the rear. The seat fiberglass height looks lower because he got the seat appolstered from the rear hump down, you can see it looks like that lip is missing where my seat sits lower than that lip so it looks to be taller. But I could be wrong.:silly:
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
Last edit: 13 Mar 2013 02:22 by Hollywoodmx.
  • 531blackbanshee
  • Vendor
  • Vendor
13 Mar 2013 11:04
#576796
i gotta say hollywood that the red seat looks like a single seat and yours looks like you could fit a lil hottie behind you :whistle: .
which ain't a bad thing if you ask me :lol: .
your bodywork has that funky cool 70's vibe.
i love the stance and everything else about the bike.
kinda on the fence over the bodywork tho,it can't help but be cool i think.
i am still waitin to see how you bring it all together with the paint
keep us posted,
