Doctorot's '78 KZ1000 build
- urankjj
- 750 R1
Re: Doctorot's '78 KZ1000 build
15 Sep 2021 23:12 - 15 Sep 2021 23:12
Hi Doc, I've been checking out these new lithium batteries from Ultrabatt, they are insanely small, I've held a single one in my hand and it is about 80% lighter than a regular battery at 430 grams !, They have an integrated circuit board that apparently stops both over and under discharging, they also piggyback together to make a bigger battery and charge in minutes. Still looking into them as they are new but so far, I know one guy racing with these in a total loss setup, amazingly small and light.... My mate knows the Australian importer ...
Just thought something like this may interest you..
www.ultrabatt.com/ultrabatt/wp-content/u..._Flyer_2014_EN-2.jpg
Last edit: 15 Sep 2021 23:12 by 750 R1.
- Shankkole
16 Sep 2021 05:17
I know Im super late to the party,But WOW!. Awesome bike/build.I will have a hard time getting this bike off my mind.I have always loved the gaudy choppers, but a clean machine like this is enough to influence my thoughts on future work I do.Thank you for raising the bar on quality.Its seems,damn near everyone of you are an engineer with a machinists background. Be well
- howardhb
- God, I trust
16 Sep 2021 07:17
Uber cool use of CAD and 3D printing!!!
'81 GPz 550 D1
'82 Yamaha YB100 Fizzie
- DoctoRot
16 Sep 2021 09:29 - 16 Sep 2021 09:30The modular nature of those batteries are cool, you will need at least 2, perhaps 3 to get enough cranking amps for a liter engine. This EarthX battery weighs 1kg/2.2lbs - 230 CCAHi Doc, I've been checking out these new lithium batteries from Ultrabatt, they are insanely small, I've held a single one in my hand and it is about 80% lighter than a regular battery at 430 grams !, They have an integrated circuit board that apparently stops both over and under discharging, they also piggyback together to make a bigger battery and charge in minutes. Still looking into them as they are new but so far, I know one guy racing with these in a total loss setup, amazingly small and light.... My mate knows the Australian importer ...
Last edit: 16 Sep 2021 09:30 by DoctoRot.
- kzstreetfighter71
- Atlantic West Coast
16 Sep 2021 12:13
What is the top amount of CCA would you recommend? is 360CCA to much?
16 Sep 2021 13:48
Sounds to be stupid but have to ask about CCA = (C)old (C)ranking (A)mpere???
16 Sep 2021 14:40
RIGHT, COLD CRABKING AMPS
- DoctoRot
16 Sep 2021 14:44 - 16 Sep 2021 14:44This is the battery that EarthX is recommending for this application. I don't know much about batteries so I cant tell you if there is an upper limit, but there definitely a lower limit or the bike will struggle to turn over.What is the top amount of CCA would you recommend? is 360CCA to much?
Last edit: 16 Sep 2021 14:44 by DoctoRot.
- 750 R1
16 Sep 2021 16:54Yes, two for a road bike, one for the race bike, One has 300CCA, so Two is plenty for any bike, they also have a no question asked 2 year replacement warranty and say they should last for at least 8-10 years...The modular nature of those batteries are cool, you will need at least 2, perhaps 3 to get enough cranking amps for a liter engine. This EarthX battery weighs 1kg/2.2lbs - 230 CCAHi Doc, I've been checking out these new lithium batteries from Ultrabatt, they are insanely small, I've held a single one in my hand and it is about 80% lighter than a regular battery at 430 grams !, They have an integrated circuit board that apparently stops both over and under discharging, they also piggyback together to make a bigger battery and charge in minutes. Still looking into them as they are new but so far, I know one guy racing with these in a total loss setup, amazingly small and light.... My mate knows the Australian importer ...
- DOHC
- Those Doe-Hawks really go!
17 Sep 2021 20:49I went with an EarthX battery because they have a 3 year warranty and are some of the only batteries for power-sports that have an integrated battery management system.
I'm still a bit skeptical of the lithium battery replacements. At least they come with built in BMS and protection circuits now, which is a big improvement.
Also, there is this statement in the FAQ:
Can I use a lithium battery in an older vehicle (before 1986)?
NO. Unless you have replaced the charging system with a new modern permanent magnet generator and rectifier regulator. It is very important to only use a lithium battery in a vehicle that has a modern charging system that will regulate the voltage between 13.8-14.6V. Older bikes/vehicles that have not been updated are not advised to use a lithium battery as the voltage will swing too high and too low at times and damage the battery.
I wish they were more clear about the requirements so someone could figure out if their bike qualifies. This page sort of suggests that the KZ 3-phase system might be fine, but I don't see anything with specific requirements for the regulator.
earthxbatteries.com/engine-charging-syst...se-lithium-batteries
But here is a question that I've always wondered about. What happens when the battery is fully charged? I'm assuming it stops accepting current, which would seem to me to suggest that the BMS removes the battery from the circuit with the regulator/rectifier. In that case, is the output of the regulator stable? Wouldn't that be the same as running the bike with no battery installed? I had the impression that the regulator doesn't really work without a battery to smooth and dampen the output.
Maybe this is why they say a "modern" regulator is required? Can you run modern vehicles with the battery disconnected?
'78 Z1-R in blue
, '78 Z1-R in black,
'78 Z1-R in pieces
My dad's '74 Z1
'00 ZRX1100
My dad's '74 Z1
'00 ZRX1100
- DoctoRot
18 Sep 2021 16:31 - 18 Sep 2021 16:34
I switched to a lithium battery specific Regulator/rectifier, after looking at that link it seems if you have 3 phase and a lithium specific R/R you are good.
Last edit: 18 Sep 2021 16:34 by DoctoRot.
