Thrown together to ride til winter
  • bluej58
  • bluej58's Avatar
Re: Thrown together to ride til winter
27 Apr 2013 23:25
#584357
Put the bearings in your freezer and they will shrink a little.
This helps for pressing them into the frame.
78 KZ1000 A2A
  • ramtough_63
  • ramtough_63's Avatar Topic Author
29 Apr 2013 23:32
#584795
Thanks, bluejay I put the races in the frame few weeks back wished I would have thought about
that might try that with the stem its a littl tight at top and where it seats havent put the bearings on the stem yet (keep thinking a miracle will happen and my front end will magically appear LOL)
too much to do and too little time to do it
I have almost decided to forego the blessing this year. it will depend on how things go
tomorrow need a valve cover gasket cam end plugs set of brake pads and a few hours
the goldwing has sat for almost a year could get it up to par in a day or so (battery cleaning
oil change etc...) its stored at a buddies house that isnt very convenient
Have enough stuff to finish for others I really need to get knocked out and wait for better
timing
just havent missed a blesssing in quite a while
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
and various enduros dirtbikes minibikes...
  • bluej58
  • bluej58's Avatar
30 Apr 2013 01:01
#584830
It's real good to hear your foot is getting better.
I know what you mean about being buried in projects Ram.
Around here there are bike blessings all month it seems, any be you can hit a later one.
78 KZ1000 A2A
  • ramtough_63
30 Apr 2013 20:00
#584992
My buffer laid down today gonna have to get another one next week
so I worked on my valve cover a few minutes when I got home today
Attachment 100_7636.JPG not found
Attachment 100_7637.JPG not found
Attachment 100_7638.JPG not found
Attachment 100_7640.JPG not found
Polished the ends & the bolts gotta let the paint
cure used VHT wrinkle paint
waiting to get a nice chromable cover to send to advance plating in
Nashville. Steve Tracy is an old KZ guy he owns the plating
company.
not gonna make the blessing this year but I figured I would rather
finish the conversion instead of spending the money to get it
thrown together in a weekend
1978 KZ1000 A2
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
  • ramtough_63
21 May 2013 11:42
#588514
making a little progress today no real time to get too much accomplished
did some polishing of my super cool fender mounts (thanks Les you rock!)
Attachment aluminum.jpg not found
fitting the front end will probably have to use my other frame
but gonna mok it all up to be certain still some painting to
do on fender brackets etc...
the upgraded brakes on the stock 19 is totally an eye catcher
still need to get a new front wheel but everything in its own time
1978 KZ1000 A2
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
  • 79MKII
  • 79MKII's Avatar
  • Love Them Kaws!
21 May 2013 13:57
#588543
Looking good! Got pics of the brakes? :woohoo:
The Kaw List:
  • ramtough_63
21 May 2013 14:46
#588555
nothing special on the brales yet but here a few shots this morning
setting the front end and getting it back on the ground still think
the header will have clearance issues I have a raked frame I think I
will have to use but I have a really hard head and will have to prove it
to myself. ordering brake lines this week
Attachment 100_7679.JPG not found
Attachment 100_7680.JPG not found
Attachment 100_7683.JPG not found
headlight bracket has been a pain
I have spray chromed it didnt like it
painted it twice and always fiddle with it and
mess it up berfore I can mount it
gonna mount the header to see if its viable or If
I should just start pulling stuff back off :woohoo:
1978 KZ1000 A2
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
  • 79MKII
  • 79MKII's Avatar
  • Love Them Kaws!
21 May 2013 17:45 - 21 May 2013 17:46
#588577
I saw that "rotor upgrade" was mentioned...are you going to install newer rotors on your stock KZ hub?
I've been meaning to ask somebody about this....when the rear tire is converted to modern rubber (wide, radial tires), what do you use on the front? You can't mix bias and radial, right? I went with modern rubber on my front wheel too but that meant I needed a much wider front rim. I'd be fine with the stocker if I had a tire combo that would work.
The Kaw List:
Last edit: 21 May 2013 17:46 by 79MKII.
  • ramtough_63
21 May 2013 18:42
#588586
i am running an ltd rotor the proof ill be in the pudding once I get her plumbed
but tires are shinko front and rear 100 up front with a tube 190 rear no tube
I am sure more modern rotors are available if you wanna spend enough
my budget doesnt allow for that making things work with the help of friends and
this site is the only way I could even have these ideas lol
1978 KZ1000 A2
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
  • kzz1king
  • kzz1king's Avatar
21 May 2013 21:11
#588603
79MKII wrote: I saw that "rotor upgrade" was mentioned...are you going to install newer rotors on your stock KZ hub?
I think the rule is that you are NOT supposed to mix bias and radial. That being said alot of guys on the older Concours do and report good handling. Have never tried it myself.
Wayne
Home built KZ1000 turbo setup
  • kzz1king
  • kzz1king's Avatar
21 May 2013 21:13
#588605
Looking good Ram. I am using Shinkos on my Concours and really like them so far. Hope the header clears for you!
Wayne
  • ramtough_63
21 May 2013 21:24
#588612
yeah ran into a snag wiring the turn signals everything went dead been running wires down all day
gonna try and fit the header before bed busting my own balls over the system going dead
gonna be a tight fit for sure but until I ride it not sure how far this front end dives
in a hard stop
1978 KZ1000 A2
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
