73 z1
  • tybolt99
  • tybolt99's Avatar Topic Author
  • From where KZs came
73 z1
04 May 2011 01:58 - 04 May 2011 02:01
#448715
This one will go really slow.
Haven't finished the last one yet. So I didn't even plan to start this one.
One day last week, took valve cover off to see what PO has done as he mentioned he messed up timing chain. Found out one of bolt head from cam chain idler were broken off.:angry: Tried to turn crank shaft, couldn't turn either way after little turn. Thought broken bolt head may be jamming chain. Took the head off.5 valves (all 4 intake and 1 exhaust) are bent. He probably messed timing up and started the engine. Of course cam chain guide (pieces of) were in the oil pan.:angry: :angry:
Will need new valves and guides, one size over pistons, all timing compornents, bored to one size up,,,,,. Pretty much same thing as the last one.
Again this gotta go really slow but add pics as it goes.
82 KZ750 H3
76 KZ900 A4
74 Z1A
73 Z1 (on the shelf)
84 ZN1300
Franklinton, NC
Last edit: 04 May 2011 02:01 by tybolt99. Reason: pic didn't go in right.
  • wireman
  • wireman's Avatar
Re: 73 z1
04 May 2011 02:08
#448721
Attachment popcorn.jpg not found
B)
  • wireman
  • wireman's Avatar
Re: 73 z1
04 May 2011 02:45
#448732
what kind of wheels are those?might of been a cool bike at one time without the mad max toe cutter fairing on it B)
  • donthekawguy
  • donthekawguy's Avatar
Re: 73 z1
04 May 2011 03:22
#448739
wireman wrote: what kind of wheels are those?might of been a cool bike at one time without the mad max toe cutter fairing on it B)
They look like suzuki wheels.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
Re: 73 z1
04 May 2011 04:37
#448749
Ouch! Still, it is nice that you'll be saving the bike. Do the VIN numbers 'match' ?
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • tybolt99
Re: 73 z1
04 May 2011 08:52
#448760
Not sure about wheels but when I searched around, found out that rear break caliper appears to be from suzuki. So wheels very well could be from Suzuki too.
VIN numbers match. Though many parts were switched or chopped up and/or rigged, still found many originals on it. Wiring harness is cut up and 3 switches were added on the handle bar and the side. :blink: Engine number is a couple hundred after they were changed to 2 piece head gasket.
I don't think I will fix it up to the original shape but thinking to make a runner with some original touch.
Some more pics are here, s897.photobucket.com/albums/ac172/tybolt99/73%20Z1/
82 KZ750 H3
76 KZ900 A4
74 Z1A
84 ZN1300
Franklinton, NC
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
Re: 73 z1
04 May 2011 10:13
#448774
The silly-cone is scary. Prime example: What squeezes out, squeezes in. i897.photobucket.com/albums/ac172/tybolt99/73%20Z1/DSC_2762.jpg
Good luck with it, I'm sure it will have a better life than before.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
Re: 73 z1
04 May 2011 10:27
#448776
nice score,
this should be a cool project!
keep us posted,
  • tybolt99
Re: 73 z1 project
14 May 2011 01:31
#450851
Engine is off the frame.
Valves are out from the head. :pinch:
Gathering parts.Got .020 1 up pistons for now.
82 KZ750 H3
76 KZ900 A4
74 Z1A
84 ZN1300
Franklinton, NC
  • dejavoodo41
  • dejavoodo41's Avatar
Re: 73 z1 project
14 May 2011 17:21
#450944
Those wheels kinda look like my rear wheel and as near as I can tell it's off of an early 900 ninja.
1977 KZ1000A With 1980 KZ1000A MKII engine, Wiseco 1105 kit, Dyna S Ignition, 3 Ohm Dyna Coils, Cams, Mikuni RS34 Carbs, Vance and Hines Pro Pipe with Comp Baffle
New Smyrna Beach, FL
  • trianglelaguna
  • trianglelaguna's Avatar
Re: 73 z1
14 May 2011 17:41
#450950
ah yes sir....you got your project board going on the wall???
it will be worth it, you got to grab those almost gone bikes if they are close by...
one day soon there will be no more in condition turning up i bet...
nice garden...
how do you keep those N.C bugs away when you are working????
good pics
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
  • T_Dub
  • T_Dub's Avatar
Re: 73 z1
14 May 2011 17:46
#450952
Those are some niiice valves! Good luck, I'm sure she'll be great!
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
