The $500 KZ1000 bobber.
  • fourstoryfame
  • fourstoryfame's Avatar Topic Author
Re: The $500 KZ1000 bobber.
31 Jan 2011 09:20
#427376
mounted seat and $15 trailer rear fender. Also incase anyone couldn't tell, those are the original handlebars just flipped upside-down
  • fourstoryfame
31 Jan 2011 09:21 - 31 Jan 2011 09:22
#427378
cut muffler and made a little baffle
Last edit: 31 Jan 2011 09:22 by fourstoryfame.
  • Stu Pidasole
  • Stu Pidasole's Avatar
  • if you aint mod'n, you aint rock'n!
31 Jan 2011 09:29 - 31 Jan 2011 09:29
#427381
looks great, how are the right turns? and whats the ground clearance from the bottom of the frame?
Last edit: 31 Jan 2011 09:29 by Stu Pidasole.
  • fourstoryfame
31 Jan 2011 10:01
#427398
from the ground to the lowest part of the fram, below the foot peg it is 6", to the lowst part of the exhaust system its 2".
The right turns arent too bad but i do get some scrapes on the tighter stuff. i could definitely use another half inch, ive been thinking about just hammering that section of the pipe flat.
  • Stu Pidasole
31 Jan 2011 10:02
#427399
so you have 6" frame height....good mines set up at 7"
  • fourstoryfame
31 Jan 2011 10:03
#427400
In some of the pics it looks SUPER low but thats before i rebuilt the fork seals.
  • fourstoryfame
31 Jan 2011 10:04
#427402
yeah you should be just fine.
  • Stu Pidasole
31 Jan 2011 10:22
#427410
what did you use....4 in 1 stock header with a tip? baffle in there?
  • fourstoryfame
31 Jan 2011 10:42
#427416
i had the kerker 4-1 system and i cut off half of the muffler piece right at the weld, leving the bead to be a nice accent to the end of my new exhaust.
  • fourstoryfame
31 Jan 2011 10:44
#427418
the baffle is from one of the metal discs from the old oil filter. sounds great.
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
31 Jan 2011 10:55
#427421
cool bike.
i am sure it hauls a$$ since the weight loss program.
  • fourstoryfame
31 Jan 2011 15:28
#427482
531blackbanshee wrote:
cool bike.
sure does! i weighed her the other day at 476 lbs.
