Growing Pains
- stonemaster
Re: Growing Pains
31 Jan 2011 01:28
ElSombreroNegro wrote:
pay no attention to him, and u dont wanna know why,
as long as ur going this far changing tank mounts should nt be a problem. I would also consider a longer swingarm to lengthen the bike slightly
show me some pics of a couple bikes you built? maybe I can see how you yourself fixed a similar issue with mad fab skills? like i said, could use the help..
- PLUMMEN
Re: Growing Pains
31 Jan 2011 01:47
hows his nomination for ambassaador to the klr650.net forum coming along? :laugh:
- stonemaster
Re: Growing Pains
31 Jan 2011 01:48 - 31 Jan 2011 01:56
Stu Pidasole wrote:
havent learned much have u JoeElSombreroNegro wrote:i amwatching...good luck. not sure how "kz" you are, but when you have done "enough" research...you might know how to make sure there is anuff room for your tank to fit......obviously i am having an issue with the tank hitting the motor, so I am going with a high mount peanut tank instead, and i have more pics i dont know how to resize, they are too big to post on here, but they show me holding the front wheel where it will go. lots of fab up done so far, much left to do yet...
I had to move motor to right side to make chain line up straight, leaving motor off center about 1/2 inch, and have to extend footpegs out more, and build new brake lever. Also need bigger battery, 200 battery does not have enough ass to turn 750 over very much.
Input welcome.. especialy considering I never done anything quite like this before...
Last edit: 31 Jan 2011 01:56 by stonemaster.
- stonemaster
Re: Growing Pains
31 Jan 2011 01:54
PLUMMEN wrote:
he may have problems with his medical checkup, cranial rectal inversion syndrome has been detected and is cause for concern :woohoo:
- PLUMMEN
- Kidkawie
- I bleed premix
Re: Growing Pains
31 Jan 2011 07:12
Poor bike. You should have just looked into a 500cc bike.
Besides all the other issues mentioned (and ones you haven't come across yet), you most likely have mismatched sprockets.
GD, no wonder it's so hard finding a good, running bike.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
- ElSombreroNegro
- Half the wheels, Twice the pleasure..
Re: Growing Pains
31 Jan 2011 09:12
oh yeah, sprockets are most definatly mis-matched! i am havining new ones made by sidewinder racing. stock 17 tooth up front, and a 38 in back, 540 size.
the wheel base is already going to be 18'' longer by moving the yoke foreward, and the raking it. I chose not to mess with the ass end if i could help it, save to put on wider rubber and and a 540 chain and sprocket to match the motor.
If i chose to lengthen swing arm later, what would it do? is it to look nice or smooth out the ride some more?
I could see how it would smooth the ride some by getting the axle out from directly underneath my seat..
(Mostly) 1976 KZ750 Twin in a (Mostly) 1978 KZ200 frame (dont ask me what I was thinking)
- stonemaster
Re: Growing Pains
31 Jan 2011 09:30
u need to research rake and trail, if ur moving forward u need to move back as well, there's a formula, i dont remember what it is,
people are gonna tell u what u should do, DO WHAT U WANNA
I saw a guy put a V 8 in 65 Renault, it actually ran. spun tires like mutha :woohoo: :woohoo:
- Kidkawie
- I bleed premix
Re: Growing Pains
31 Jan 2011 10:21
So you're going to use the 200cc rear hub? That's pretty nuts since it's basically a glorified moped chassis.
1975 Z1 900
2004 KX125
2004 KX125
- ElSombreroNegro
Re: Growing Pains
06 May 2011 20:03 - 30 Jun 2011 00:06Attachment IMAGE_020.jpg not found
Attachment IMAGE_036.jpg not found
Attachment IMAGE_043.jpg not found
Here goes a few, Have a whole lots more...
Last edit: 30 Jun 2011 00:06 by ElSombreroNegro.
- ElSombreroNegro
Re: Growing Pains
06 May 2011 20:08 - 27 Jun 2011 23:56Attachment IMG_20110504_105530.jpg not found
Attachment IMG_20110504_105600.jpg not found
Attachment IMG_20110504_105543.jpg not found
more
Last edit: 27 Jun 2011 23:56 by ElSombreroNegro.
- ElSombreroNegro
Re: Growing Pains
13 Jun 2011 23:48 - 30 Jun 2011 00:09
Got it running! had it going down the road today. good times.
Attachment IMG_0259.JPG not found
Attachment IMG_0262.JPG not found
Last edit: 30 Jun 2011 00:09 by ElSombreroNegro.
