'78 KZ1000 makeover
- dcmspikes
Re: '78 KZ1000 makeover
03 Aug 2013 18:39 - 03 Aug 2013 19:52
ha, nice. well ,really, if you need a hand and you can wait for a weekend, just say the word. be good to get out of town for a minute get some motivation to work on my projects. looking good.
also, i just came across this
forums.kz650.info/index.php?topic=10539.0;topicseen
www.boltdepot.com
www.boltdepot.com
Last edit: 03 Aug 2013 19:52 by dcmspikes. Reason: more info
- CruisingRam
03 Aug 2013 20:12
I think I bought my last set of case hardware, stainless, high quality, from Z1 or a place like it- I will try to go through some old orders on my computer, and see if I can find you something, the main thing I remember about them is that they were all allen heads and high quality, not the butter-bolts that came stock.
1975 Z1 B 900- soon to be heavily modded
Pahoa, Hawaii is my new hom
I am working hard to save up the shipping money to get my shop opened here in Hawaii
I hate electrical stuff.
- Powerstroke_fan
03 Aug 2013 22:38porchev914 wrote: Lucky me, the stealership had one!! Who would have thought? :whistle: But of course, another little snagI seem to have misplaced the tab washer for the drum locator bolt....I suppose its time to make a new one.
On a side note, has anyone ever purchased new case hardware? The bolts are exceptionally expensive from places like bike bandit at $2-$4 each :blink: My hardware looks like trash, and its going to be tough putting crappy looking hardware on my new pretty engine. Has anyone had luck cleaning up the stock stuff?
Its a good thing the dealership had that 18mm o ring. when i assembled mine i had to wait on that same o ring. By the way its a good thing you bought that because you will need two all together anyway.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
- porchev914
04 Aug 2013 02:36
You're absolutely correct powerstroke, 2 are required. I have 2 on order, so I'll have a spare
Oddly enough, the dealership had 4 in stock!
FRANKEN Z!
- Powerstroke_fan
04 Aug 2013 09:22
sorry porchev914, i thought above you said you only ordered one, Thats why i said that. Your engine is looking real nice so far.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
- porchev914
04 Aug 2013 14:56
No apologies man, my post was ambiguous. I did say I was waiting on one particular 18mm o-ring to assemble the cases. I would have made the same assumption
FRANKEN Z!
- porchev914
05 Aug 2013 02:21
I drug my freshly painted frame into the house and laid out a harbor freight $6 moving blanket and wend to work this afternoon :woohoo: First went in the assembled bottom end:
I seemed to have misplaced some of the bottom motor mount hardware, so I made some new ones out of stainless nuts and some 1/4" stainless rod. Stock on the left, my stuff (including a titanium motor mount plate) on the right:
Then I got the rear suspension bolted up:
Followed with the front end:
FRANKEN Z!
- porchev914
05 Aug 2013 02:26
Once my Z1E order shows up tomorrow or Tuesday, I'll get the pistons and jugs on. For those who have assembled these engines before, what's your take on copper coating for the base gasket? I've heard it both ways, and I definitely do NOT want a base gasket oil leek!
FRANKEN Z!
- Harvey1327
05 Aug 2013 02:46
Looking good mate. I have a copper base gasket which does not leak but I used the standard head gasket as the copper head gasket always leaked no matter how or what sealant I used.
1 x 77 Z1000
1080,cams,ported
29 smoothbores,
Akron rims,Martin Swingarm
1 x 77 Z1000
1327 Wiseco,cams
ported,34.5 S/bores
GSXR swingarm
RF900 frontend.
1 x 2008 Nightrain
shotgun shock,corbin
seat,fat bars,some bling.
www.kzrider.com/media/kunena/attachments/8119/IMG_0461.JPG
1080,cams,ported
29 smoothbores,
1 x 77 Z1000
1327 Wiseco,cams
ported,34.5 S/bores
GSXR swingarm
RF900 frontend.
1 x 2008 Nightrain
The following user(s) said Thank You: porchev914
- testarossa
05 Aug 2013 07:42porchev914 wrote: Once my Z1E order shows up tomorrow or Tuesday, I'll get the pistons and jugs on. For those who have assembled these engines before, what's your take on copper coating for the base gasket? I've heard it both ways, and I definitely do NOT want a base gasket oil leek!
I did the copper coat on mine when I put it together. I haven't had any leaks around the base gasket at all. I did spend a bunch of time making sure that the mating surfaces were perfectly clean before I assembled it.
BTW the bike is looking spectacular!
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
2004 ZX-10R
Angola, IN
- Powerstroke_fan
05 Aug 2013 08:02
I put mine together and my base gasket leaked bad. So i bought some gasganich as suggested by cometic gaskets. Of course iam bored out to 80mm also, but i really hope its stops the oil leak. I will hopefully be putting the top end baxk together tonight.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
- 79MKII
- Love Them Kaws!
05 Aug 2013 10:14
That looks awesome! It's exciting to see it coming together. :woohoo: I'm sure you're a little excited too! :lol:
The Kaw List:
