Testarossa's 78 KZ1000 Fighter Build
  • trianglelaguna
  • trianglelaguna's Avatar
Re: Testarossa's 78 KZ1000 Fighter Build
12 Aug 2011 18:51
#468665
T-dub in the house
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
  • testarossa
  • testarossa's Avatar Topic Author
15 Aug 2011 18:56
#469226
MMM new pistons. Tasty! Getting closer to the 1075cc upgrade every day. Lets see, 10.5:1 MTC's, APE K410's and VM29 Smoothies. Sounds like a good combination for a street bike to me. Anyone have a recommendation for valve sizes? Are the 29mm carbs going to hold this setup back? Eventually one of these heads will get a stage one port, but I'm itching to get this setup installed this winter. The blue streak will get a much needed power boost.
Attachment aP1010480.JPG not found
Attachment aP1010479.JPG not found
What's up Tyler? Did you figure out where you were moving to?
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
  • T_Dub
  • T_Dub's Avatar
15 Aug 2011 22:38
#469272
Those are some nice pistons. I love nice fresh pistons.
Turns out I'm moving to...nowhere. Staying here in NL for now. Should be able to get out at the bike on Sunday, hopefully my Z1E order will be here by then.
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
  • trianglelaguna
15 Aug 2011 23:39
#469289
cool...i have never seen them in truck beds ,,where do they go....
1976 KZ900
2003 ZX12R
2007 FZ1000
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
16 Aug 2011 08:51
#469332
are u sure there 10.5:1 ? they look tall in the pic ?
stock valve size will be best for that combo. it will keep the torque low where u want it. u have a zx10 for the high end. keep the kz running where it shines most. B)
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • testarossa
16 Aug 2011 09:11
#469334
Keen observation Mark. Joe at Pit Stop sells two versions of the 10.5 to 1 pistons. These are for longer duration/higher lift cams. He says not to use them with the stock cams as they will provide too much compression for a street bike. I told him that I wanted what ever set that would be best with those K410 cams, and this is what he said to use.
Don't worry Craig, I'll show you where they go, and no, it's not in my truck bed.
2004 ZX-10R
Angola, IN
  • trianglelaguna
16 Aug 2011 09:54 - 16 Aug 2011 10:02
#469343
yeah yeah nice indeed....every one is snapping up those other piston kits too and i can see the savings...i figure i will be doing a bit more specific purchase like you did..and if they sell out of those japan sets no big ...i like the pop tops and had some in an engine with 29's.....way fun.....nice...are you doing any coating...how is the finger....
Adam stopped by my house Sunday...rode a bike and the kids ran around....was here a good bit....nice guy....he rode the MKII :)
edit:
i kicked myself right after they left for not taking a picture or video clip with him on the bike(in flip flops) or us next to the bikes ect....i did not want to get the creepy camera out when they pulled up, and we were just meeting and his wife and kids were running through the garden ect...i all but forgot i had the cameras in the shop loaded to get a bike pic with him....next time...p.s he is the holder of the Moriwaki tip and titanium mid pipe from a daytona Z1 now...let him make it work on that hybrid carbon beast....
when are you doing the engine....there may be a few of us doing small blocks this winter :ohmy:
1976 KZ900
2003 ZX12R
2007 FZ1000
Last edit: 16 Aug 2011 10:02 by trianglelaguna.
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
16 Aug 2011 13:08
#469377
nice pistons there sir :cheer: !
that should be a very good running combo.
i cannot believe that craig slipped on getting the evidence on adam :angry: .riding in flip flops :( .
jee wheel lickers wally!!!!!
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
16 Aug 2011 13:19
#469379
testarossa wrote: Keen observation Mark. Joe at Pit Stop sells two versions of the 10.5 to 1 pistons. These are for longer duration/higher lift cams. He says not to use them with the stock cams as they will provide too much compression for a street bike. I told him that I wanted what ever set that would be best with those K410 cams, and this is what he said to use.
quote]
Wow! Never heard that 1 before. i hope u dont get any ping.
You may want to reduce your squish area to help.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • tachrev
  • tachrev's Avatar
  • Rubber Side Goes Down
16 Aug 2011 13:35 - 16 Aug 2011 13:53
#469383
They are just standard 10.5:1 MTC pistons, so they will work great.
It should be a nice setup when it is done.
Pit Stop sells the same pistons with machined domes for stock cams.
Their sales pitch for them drives me crazy, although I understand what they are trying to achieve.
10.5:1 pistons are 10.5:1 pistons, regardless of the cams.
The 10.5:1 is the static compression ratio, which is can be derived using math. It is based on chamber volume and is not affected by the cams or cam timing.
Build Thread
Last edit: 16 Aug 2011 13:53 by tachrev.
  • T_Dub
  • T_Dub's Avatar
16 Aug 2011 15:39
#469403
I'm with tachrev, all of that doesn't make any sense to me. Compression ratio is compression ratio, cams have nothing to do with it. They might have deeper pockets to clear the valves due tot the greater lift/duration. In which case, if they're machined from normal MTC 10.5:1 pistons the static CR would be lower as you've removed material. I think Joe is either full of shit or you heard him wrong.
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
16 Aug 2011 15:57
#469406
Sorry. i didnt mean to open a can of worm here. not to worry , it probably just that they look dif in the pic.
TDub. longer duration cams WILL bring down the compression ratio. thats why u need more compression to run bigger cams. ;)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
