- Thank you received: 5
Testarossa's 78 KZ1000 Fighter Build
- camaroguy
- mark1122
- Keep twisting it
- Thank you received: 109
i've forgotten? did u post all of whats involved for that led conversion and flasher, in here somewhere?
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- testarossa
- Thank you received: 82
Very cool. i like the flashing.
Mark, I showed the physical mounting stuff, but not the wiring. It's really simple once you figure out which wires on the new taillight operate which functions. They didn't send a detailed wiring diagram since it had the connectors to plug into the R6 factory harness. I actually hardwired it into the original KZ taillight connector, so it plugs in just like a stocker.
Camaroguy, I will steal the gas tank off my son's go-kart for a temp. fuel source. He will be pissed off at me for it, but he can deal for a couple of days. That kid doesn't miss anything.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
- trianglelaguna
- Thank you received: 235
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
- mark1122
- Keep twisting it
so u bought a plug in led unit for the r6 lt?
did u need anything else to make it flash?
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- testarossa
did u need anything else to make it flash?[/quote]
No, the taillight included the sequential flaser unit. I actually seems to work with either a constant 12v input or with the pulsed input from the standard flasher can. I currently need the regular flasher to operate the front turn signals, so the taillight gets the pulsed 12v from the normal KZ wiring. It even keeps time with the front turn signals.
2004 ZX-10R
Angola, IN
- mark1122
- Keep twisting it
It looks great. well done.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- testarossa
First you remove the stock timing cover and all the components of the points ignition. Next you replace the stock rotor with the one that Dyna provides:
Then you install the Dyna crank trigger plate:
Leave the screws loose at this point so you can rotate the plate when timing the bike. Make sure to connect the four pin connector to the main harness for the ignition.
Next it instructs you to remove the spark plugs and rotate the engine until the trigger for cyls. 2 and three lights the LED on the control box. Then you rotate the plate until the the led is lit at the 40* mark. Now you tighten the three mounting screws and lock the timing in place.
I set my control box atop the clutch cover to see the LED while turning the engine.
With the timing correct for 2 and 3, you move on to adjusting the timing for 1 and 4. Here's where I was somewhat confused. It says to rotate the engine 180* to the same 40* mark for cylinders 1 and 4. You are then supposed to move that particular sensor to light the LED. I couldn't tell from the instructions, which sensor was for 1 and 4. I just tried one and of course it was wrong. Then I had to re-do 2 and 3. Now back to 1 and 4. The proper sensor to adjust is the left one that I pointed to in the next pic:
Now you just replace the timing cover and secure the wiring. The static timing is complete, and you should be able to start the bike.
2004 ZX-10R
Angola, IN
- testarossa
Well I stripped the float bowl off and discovered that the small brass overflow tube had a hairline crack that ran the length of the tube. So, in the interest of getting her started, I soldered the tube, and it seems to be holding for now. Not sure how it cracked or if it will hold, so I'll be looking for a float bowl and two of the chrome caps to fix the issues with this carb set.
Ok, so I install the carbs, air filters, and hook up the throttle linkage. Connect the go-kart gas tank, and say a little prayer.
IT'S ALIVE!!!!!!!!!!
2004 ZX-10R
Angola, IN
- DoubleDub
- Visitor
- porchev914
- Thank you received: 19
FRANKEN Z!
- Nelson
Restoring and customizing a KZ1000. Click here to read about it.
Plated KTM, DR650, KZ1000, Former MC mechanic (eons ago). 40 yrs. of dirt and street.
