- Thank you received: 82
Testarossa's 78 KZ1000 Fighter Build
- testarossa
I still need to check the float height on those carbs before I bolt them in place. I'll have to come up with some temporary fuel source in order to do that and once I start to sync the carbs with the bike running. In order to get to the stage of hitting the start button, I have just a few things left. Set floats, install carbs, install wiring, hook up the Dyna 2000 for real, top off the oil, and add fuel. Am I missing anything? Anyone have a good, cheap DIY, hang up fuel bottle solution? I may just get there by this weekend.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
- Nelson
Restoring and customizing a KZ1000. Click here to read about it.
Plated KTM, DR650, KZ1000, Former MC mechanic (eons ago). 40 yrs. of dirt and street.
- testarossa
2004 ZX-10R
Angola, IN
- mark1122
- Keep twisting it
- Thank you received: 109
I use a plastic tank out of a lawnmower. and rope or bungees
X 2.
Sounds like u are getting close.
if u do a bench sync with a 1/16th drill bit. it will run just fine like that . then later u can do a full sync on the bike.
that way u can just start it and go for a rip . :woohoo:
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- tk11b40
- Thank you received: 19
You have got to let us know how well it works for you. I would really like to get one but am struggling with the 400 dollar price tag.
If it works well and is worth it I have no problem spitting out the cash, but I hate buying stuff that does not work well.
Very nice work!!
Suzuki GSXR 750 slabside
Ducati S4R
Husqvarna FE 350s
- testarossa
2004 ZX-10R
Angola, IN
- testarossa
2004 ZX-10R
Angola, IN
- porchev914
FRANKEN Z!
- mark1122
- Keep twisting it
Good luck.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- T_Dub
- Thank you received: 25
And guys, electrical is easy, V=IR to know how many amps are in a circuit, and for sizing wires you can just use P=RI^2. Ok, maybe more to it than that but its not that bad.
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
- testarossa
I agree with you guys. I can see mechanical systems and understand in my head how they work. Sadly, I can't see the electrons moving so I have a harder time with the wires. It always goes the same for me with the electrics. I learn it for long enough to solve my current problem, and once I'm past the problem it's all gone from my head again.
It seems that something is shorted to ground in that switch pod. All I know to do is eliminate everything, and start plugging stuff in until the fuse blows. When I got to the the solid brown wire it popped the fuse. I should know more in just a minute.
2004 ZX-10R
Angola, IN
- testarossa
2004 ZX-10R
Angola, IN
