- Thank you received: 5
Testarossa's 78 KZ1000 Fighter Build
- camaroguy
- trianglelaguna
- Thank you received: 235
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
- mark1122
- Keep twisting it
- Thank you received: 109
Mark, how is your bondo holding up in those welds? I'm scared of using too much filler. I would hate to have a chunk of filler pop out when the frame tries to flex. If anyone can make it flex it's gonna be me.
No problems so far. i'm sure the bond will flex that much, just like the paint does. just put some nice stainless washers between all bolts and paint. without a washer the paint can chip during tightening of the bolt.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- porchev914
- Thank you received: 19
FRANKEN Z!
- porchev914
Plastic body filler is pretty flexible stuff. It won't withstand concentrated compressive loads well (bolt tightened against it for example) but it is especially designed to bond to steel and flex with sheet metal. I'm certain that the bed side of a truck quarter panel flexes much more than our frames do, and I've put barrels of bondo on them :laugh: If you needed to cheat with some body filler to smooth out some hard (or impossible) to reach areas, IMO, it shouldn't present an issue in the future
FRANKEN Z!
- testarossa
- Thank you received: 82
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
- porchev914
FRANKEN Z!
- testarossa
I'm not sure how much more work I want to put into prettying the frame. I question my sanity every time I start working on a weld. I have already given myself tendinitis in my right elbow. Sometimes I think that I may have a touch of OCD. I could have just painted the frame and 99.44% of people would never notice. I guess that it is my calling card, and I can't do it any other way. Unfortunately I'm putting a $15,000 effort on a $3000 bike.
Don't take it the wrong way. Sometimes the voices in my head have to speak up. :ohmy: I'm not griping about what I have to do, I wouldn't build it if I didn't enjoy the work. But my elbow does hurt.
2004 ZX-10R
Angola, IN
- PLUMMEN
- Thank you received: 104
ya cant chrome bondo! :laugh:i cheated and use bondo.
Nice job.
- porchev914
FRANKEN Z!
- testarossa
Nice job.
True, but you couldn't pay me to chrome this frame.
2004 ZX-10R
Angola, IN
- testarossa
1 more thing Josh, DO NOT KILL YOURSELF trying to go over the entire frame with 320 or whatever the PPG recommends for the epoxy primer. It is more important in the areas where you have filler. 100 grit will not leave nearly the scar on the steel frame as it will on the bondo, so finish your filler spots with the recommended grit. The frame will be fine with a 120 or 180 or whatever finish you've got on it. If your worried about grinding scratchs showing up, test spray a spot of the frame. If it needs more work, do it, if not, spray away
Thanks again for the good advice. I have painted some steel parts that were sanded to 120 before, and they looked good to me. Actually my original plan was to fix the fillets, and then sandblast everything one last time to even out the finish. I realize that I cannot blast any areas that I have used plastic filler. We'll see...
2004 ZX-10R
Angola, IN
