Testarossa's 78 KZ1000 Fighter Build
  • testarossa
  • testarossa's Avatar Topic Author
Re: Testarossa's 78 KZ1000 Fighter Build
28 Jul 2010 21:54
#386716
PLUMMEN wrote:
didnt your mama ever tell ya you could put an eye out with an air gun?id suggest an impact wrench myself! :laugh:
Damn! I was just heading to the store to get some pellets. The BB's weren't cutting it.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
  • testarossa
01 Aug 2010 20:02
#387556
Back to work now. I got the bottom end of the motor all assembled this weekend.
After all the previous discussion of the oil pan gate mod, I decided to go the same route as mark1122. I drilled and tapped the oil filter housing for a M6 and bolted the hinge in there.
Here's the bottom end all buttoned up.
2004 ZX-10R
Angola, IN
  • testarossa
01 Aug 2010 20:16
#387567
After I got the thing flipped I got the pistons re-installed.
One tip is to use a heat gun to warm the pistons before you try to install or remove the wrist pins. I prefer the heat gun to a torch.
Next, I slid on the cylinders.
A couple of notes on installing the cylinders. It seems that there has been considerable discussion on the forum lately about the presence of o-rings at the base of the KZ1000 cylinders. Mine were predictably, very hard and brittle. They came apart into a million pieces. However, I actually got replacement o-rings in my gasket set, so I installed them. I bought the Vesrah set from Z1E. I must say that these are the easiest pistons that I have ever installed on a engine that I have built. That chamfer on the bottom of the cylinders makes it so easy to get the rings compressed.
Here's my clutch marinating for tomorrow.
2004 ZX-10R
Angola, IN
  • porchev914
  • porchev914's Avatar
01 Aug 2010 23:57
#387590
:cheer: :cheer: :cheer: :cheer:
Kudos Josh! You're getting sooooo close! I am envious, but my hope is that my little composite detour and sidework for another Kz owner will help put me back on financial track. It's nice to watch you get closer though ;)
FRANKEN Z!
  • testarossa
03 Aug 2010 20:42
#388016
A quick update to my engine build. I managed to get the clutch installed this evening. On a sad note, I realized that I neglected to install the cam chain roller in between the upper case half and the cylinder block. Hopefully, I can just lift the cylinders enough to slip that roller in there.
2004 ZX-10R
Angola, IN
  • porchev914
03 Aug 2010 20:50
#388017
It's sooo puuuurdy Josh! I can't remember, have you already painted your frame? I know we were talking about semi gloss paint, but I don't recall the outcome..
FRANKEN Z!
  • testarossa
03 Aug 2010 20:56
#388018
Sorry, no paint on the frame yet. You know that I would post a picture if I had cleared that hurdle. I still have a little bit of welding to complete, and I want to check the alignment of the neck closely before I paint it. I also have a small side project for another member that needs to be fabricated so that I can paint that at the same time.
2004 ZX-10R
Angola, IN
  • tk11b40
  • tk11b40's Avatar
03 Aug 2010 22:58
#388034
Very nice project...
I am at work and no doubt could get lost reading all this.
top notch work.B)
Suzuki GSXR 750 slabside
Ducati S4R
Husqvarna FE 350s
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
04 Aug 2010 07:34
#388069
just a thought.
When I did mine, i was wondering if it was possible for the gate to open all the way and get stuck open due to the angle. After playing with it a bit . I decided to use a longer bolt in with a jamb nut to secure it. The longer bolt does not allow the gate to swing open as far. Is it necessary??? Just a little insurance.
good to see all of the positive progress.B)
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • testarossa
04 Aug 2010 19:41
#388250
top notch work.B)
I really appreciate the kind words. You don't know this, but your bike has served as inspiration. I had a keen interest in your build in my lurking days.
I hope to include a table of contents in the future to help people navigate my thread.
2004 ZX-10R
Angola, IN
  • testarossa
04 Aug 2010 19:46
#388253
mark1122 wrote:
just a thought.
Thanks for looking out man. I actually had the same thought. That bolt head protrudes fairly far (about 7mm or so.) I put a considerable amount of work into fitting the two parts of the hinge so that it moves very freely. I think that any large slosh of oil should catch it and close the door. I hope....
2004 ZX-10R
Angola, IN
  • testarossa
04 Aug 2010 19:58
#388256
Now on to tonight's progress. First I had to remove the cylinders to install that cam chain roller that I missed.
Don't skip that one.
Next, I got the jugs back on and the upper rollers in place.
Then the head .
Finally, I got the intake cam back in place with the new cam bearings. Those bearings sure are an improvement over the blistered parts that came out of the motor. I'll try to post a side by side photo tomorrow.
2004 ZX-10R
Angola, IN
