- Thank you received: 797
Testarossa's 78 KZ1000 Fighter Build
aw,just joking man.
i have turned the dohc off of 3 or 4 points covers and 2 or three alt.covers.there are some points covers that are thinner than the others.if you look at the back of the points cover and you can see the impression of the dohc boss and some strengthening ridges,those are thin.i turned one off and my buddy came by a few days later and said 'man my bike is making a wierd singin sound'i said "start it up".you could hear a high pitch ringing sound,i cocked my head(like a dog)and walked over and put my hand on the points cover and it stopped.my buddy was like what the hell.i guess we got it thin enough that the harmonics would make it sing.you don't have that problem with the thick ones tho.
- testarossa
- Thank you received: 82
Actually that would be cool to mill something in those covers, and I could make that happen fairly easy at work. However, I think that I would have to start by flycutting the tops. They aren't exactly flat. I was noticing that the clutch cover is like a funhouse mirror when you polish it.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
i don't know jack about cnc.
- testarossa
they are a compound curve.could you not just set the cutter depth and then let the depth vary with the curve?
It can certainly be done, but it's way more complicated that simply writing an engraving program for a flat surface. Following the curve involves 3-D milling where you are interpolating through all three axes at the same time. Basically you are having to use a ballnose endmill, and calculating the tangent points in all axes for every move. The amount of trig becomes staggering, and normally the 3-D programs are all written by CAM software. We have the facilities, but I usually try to keep the "Government Work" quick and easy.
2004 ZX-10R
Angola, IN
- porchev914
- Thank you received: 19
FRANKEN Z!
- testarossa
All I know is that if you run a clearanced point cover, then you better be able to put some scratches in it without putting the bike down.
BTW I got my exhaust valves back in tonight.
Let me take a crack at naming my race team. Phuc Loo Sing!
2004 ZX-10R
Angola, IN
- porchev914
FRANKEN Z!
- PLUMMEN
- Thank you received: 104
i give credit to my dear ol dad for coming up with the plain jane covers look origionally back in the early 80s around these parts anyway,along with the color coordinated frame/bodywork that seems so popular these daysgood job testa!
i like how you spun the dohc off the covers.
lookin good man,
- testarossa
So I finished sticking the head together this evening. Almost made a classic mistake. After I had five of the valves all snug in their holes I realized that I forgot to install the valve stem seals. One quick pointer for those who have not built these heads before. Make sure that the lower spring seat is in place before you install the valve stem seal.
2004 ZX-10R
Angola, IN
- mark1122
- Keep twisting it
- Thank you received: 109
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- testarossa
Here you can see my broken spring.
Here's what they look like after I removed them. Two were loose and you can see the broken one.
Now in order to get everything apart, you have to drill out the three rivets that hold the basket assembly together. Once you get the centers drilled out of the rivets, then you can use a punch to drive them out the other side. They are a press fit in there.
Here's what you need to fix the problem. APE heavy duty clutch hub rebuild kit. Two things to note about the APE kit. All six of the hub springs are the heavy gauge wire. Half of the stockers were heavy, and half were a lighter weight spring. Also, the new rivets in the APE kit are larger diameter (.437" vs .370") than the stock rivets. This means that you need to drill out the holes.
The steel backing plate on the back of the basket is very hard steel. I thought that my drill was cutting well since I saw steel chips coming out of the hole, but the chips were from the drill.
In the end, I had to grind the holes larger, and I used up four grinding stones on my Dremel tool.
Here it is mostly back together. I ran out of time to finish it, but should be done tomorrow.
I must say that I am pleased with the quality of the APE kit. Everything fit together well.
I also discovered another broken case bolt that I didn't know about. It is broken off inside of one of the dowel pins on the alternator cover side of the engine case. I don't think that I can weld anything to it to get it out.
2004 ZX-10R
Angola, IN
- PLUMMEN
yep still sitting in the basement wating for next phase.that bike was done that way back in 82,the covers were also milled down back then.he was ahead of the times to put it mildly! :laugh:So Plum, was that Dad's bike? That takes guts to paint your frame red, but it looks good on that bike. I think I'll stick to black for mine.
