Testarossa's 78 KZ1000 Fighter Build
  • freebyrd24
  • freebyrd24's Avatar
Re: Testarossa's 78 KZ1000 Fighter Build
28 Mar 2010 12:02 - 28 Mar 2010 12:02
#356735
x2 on the tail light
Definitely lookin reeeeal slick with the corners tucked up under the tail. keep up the awesome work! :woohoo:
- 1981 KZ1000-K1 LTD - Long term project
1075cc Kit - New Wiseco Pistons
Sold:
- 1978 kz650 SR, 4-1 Vance and Hines Full Exhaust, Dyna-S Ignition, Accel Coils and Wires
Last edit: 28 Mar 2010 12:02 by freebyrd24.
  • porchev914
  • porchev914's Avatar
28 Mar 2010 12:50
#356740
Bro, good call on the light....how did you know it was going to work out, or was it a gamble? I would do something similar if I wasn't planning to have a muffler right where your tail light is B)
FRANKEN Z!
  • testarossa
  • testarossa's Avatar Topic Author
28 Mar 2010 19:00
#356810
This thing with the taillight has been something that I have studied for a while. As soon as I decided to do the conversion, I knew that I wanted an integrated LED. I also knew that the only way to get that would be to adapt one from a modern sport bike. Now there are loads of em on ebay, but if you ask the sellers to measure them for you, then you get responses like "Its the stock size." Most of those guys don't even see their own inventory, and wouldn't open the box even if they did.
I knew that I could make the zx-10r light work since I have one to measure, but the side profile is a little off. So unbeknownst to many local riders, I have been scoping out there taillights for a while now. In the end it was a bit of serendipity that paid off. I don't seem to ever wind up riding with anybody on a R6. If you go back and look at the ebay ad that I posted the link for, you will see that he has a license plate directly below the light. My brain says "Hey that taillight is the same width as the plate." So I go and hold up a plate under my tailpiece and voila its the right width.
Now the upside down idea is a trick that I learned by watching Overhaulin one time. I remember Chip Foose taking a bumper and mounting it upside-down on the same car. Genious! I filed that one away in the ole mental database for future use. When customising, never limit yourself to viewing the part in only its correct use. Garage Confucious say "Sometimes the only proper thing to do is the incorrect thing."
With all that said, when I saw the sequential blinkers I was sold. Always wanted to do that with my old Mustang with those three bar taillights. Just like a '68 Cougar.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
  • testarossa
28 Mar 2010 19:28
#356812
Here you go boys, from the Testarossa Skunk Works I give you a functional rearset. It still needs some bracing, and I know that I want to reshape the heel guard a little bit. I am pleased to report that the MC is mounted and operational, and the brake lever works beautifully. Now that I have the hard side done I can complete the shifter side. Here's to the hope that it doesn't interfere with the exhaust.
Mark, are you able to use your kick starter with your rearset position? I pretty much put my pegs where you have yours.
One of my buds at work has loaned me a sandblaster indefinetly, so you should see some better looking cases in the near future. I'm soo stoked for this week. Most of my engine parts should be here as well as the chain and sprockets.
2004 ZX-10R
Angola, IN
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
28 Mar 2010 20:19
#356825
Sorry bud. cant help u there. i dont have a kick start.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • testarossa
28 Mar 2010 20:23
#356829
I can't remember how far down it travels when you kick it. I guess I'll find out soon enough. What's the story on your CB900 starter anyway?
2004 ZX-10R
Angola, IN
  • StreetfighterKz
  • StreetfighterKz's Avatar
29 Mar 2010 04:50 - 29 Mar 2010 07:49
#356878
I have Tarozzi rearsets on my 1000. You can still use the kickstarter but you lose 1/2 of the original travel. If your bike is easy to start its not a big deal. But if it's harder to start then you'll probably need all the travel you can get.
Later, Doug
1978 z1000 Streetfighter
1976 z900 Stripfighter
1978 Z1R (roller)
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
Last edit: 29 Mar 2010 07:49 by StreetfighterKz.
  • testarossa
29 Mar 2010 05:05
#356880
Thanks Doug. That was my suspicion. Not sure how much I'll use the kicker anyway. I had thought that I might make it a kick start only bike in the beginning, but Father-in-law has a Harley thats a kick only bike. Watching him start that bike on a cold morning changed my mind.
2004 ZX-10R
Angola, IN
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
29 Mar 2010 05:49
#356884
I have a starter from a 78 CB900f.There are a few dif bikes that have the same starter. they used 8 kilowatts, the kz is 6kw. the end result is the honda starter turns over noticeably faster. U have to clearance the sprocket cover for the starters power bolt, and the kz top cover sits a little proud.
I did this because i was worried about starting my 1327cc motor.
It works great.i also added a thicker wire to the starter like the honda has, and a stronger battery. She turns over much better, but i wouldnt say it is a necessity, just a luxury.
I feel more confident with it combined with big cc's.B)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
29 Mar 2010 11:39
#356948
rearsets turned out pretty nice.
it is so hard to take a couple bolt holes and go "okay i need a bracket from here to here and there and a pivot here(somewhere)and a mount for the master cylinder and a way to activate the master cylinder and a place for my foot and.........".
if you have never tried to "dream up" some custom stuff you don't understand what a mind fu!< it can be.i have built a couple sets of conrols (rear sets and forward controls)and can appreciate your work.
the honda starter starts my bike(1980 z1r stock) much faster and easier than the stock starter.i am happy every time i hit the button that i did the mod.
  • porchev914
29 Mar 2010 16:33
#357034
X2 on the rearsets buddy. Once they're painted, no one could tell them apart from Tarozzi's ;) Lets see....if I remember your list correctly, just a few more things until you are on the road!
FRANKEN Z!
  • testarossa
30 Mar 2010 05:15
#357144
Thanks guys. You havn't seen the last of the rearsets yet. I'm going to add some speedholes to the heel guards. Havn't decided on the design yet. There will also be some strategic lightening/reshaping of the levers, but the brake lever side is functional. I still have to assemble the shifter side and decide how to match the heel guards as well as possible. The mounting of the left side heel guard will need to be a little different. The right side is mounted with the bolts that hold in the MC and it is spaced out about 3/8". Not necessary or even possible with the shifter side.
Got my clutch hub rebuild kit in from APE yesterday. I'm really starting to think that the clutch is what took this bike off the road. Between the added plates, super thin friction plates, and broken hub spring, I'm guessing that the clutch was a little "difficult." Did the PO do some drag racing back in the day?....
2004 ZX-10R
Angola, IN
