Testarossa's 78 KZ1000 Fighter Build
- mark1122
- Keep twisting it
Re: Testarossa's 78 KZ1000 Fighter Build
17 Apr 2011 09:22 - 17 Apr 2011 09:23
Congratulations. u deserve 1 of these.
and 1 of these
and 1 of these
Attachment clapping-hands2.gif not found
and 1 of these
Attachment 3d_rolllaugh-57x43_2011-04-17.gif not found
and 1 of these
Attachment 3d_knockout-53x53.gif not found
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 17 Apr 2011 09:23 by mark1122.
- testarossa
20 Apr 2011 11:30
Well, I got the rest of my jet blocks repaired with the new brass threaded inserts yesterday. All of my new jets came in, and I got the rest of the caps polished last night. Hopefully, I can get the carbs fully clean, and re-assembled in time to install before this weekend. I can't wait to see the difference between 26's and 29's.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
2004 ZX-10R
Angola, IN
20 Apr 2011 11:55
Forgive if already mentioned, but this cleaning method works well on smoothbores.
The small air jet is easily overlooked, and is removable for cleaning.
- testarossa
20 Apr 2011 12:29
Thanks Patton. That air jet is a small bugger. I should be doing this tonight if I get time.
2004 ZX-10R
Angola, IN
2004 ZX-10R
Angola, IN
- testarossa
21 Apr 2011 02:13
Got those carbs stuck back together this evening. Still need to do a bench sync, and adjust fuel level. Should be making fire with these this weekend.
Everything went back together smooth with new pilot jets, main jets, jet needles, and needle jets.
I guess that the ballpoint pen trick won't work on these float bowls for the clear tube test.
Attachment aP1010150.JPG not found
Attachment aP1010152.JPG not found
2004 ZX-10R
Angola, IN
2004 ZX-10R
Angola, IN
21 Apr 2011 08:18testarossa wrote: ...Still need to do a bench sync, and adjust fuel level...I guess that the ballpoint pen trick won't work on these float bowls for the clear tube test.
Handsome carbs!
Could use a modified drain screw:
www.z1enterprises.com/detail.aspx?ID=4341
Or fab your own.
And might also find on ebay.
I get by just fine with a tube inside a grommet (cone-shaped if available) pressed inside the drain hole:
- mark1122
- Keep twisting it
21 Apr 2011 08:47
just remember to mark the tube. this way the same amount of fuel comes out of the bowl each time and the results remain accurate.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- testarossa
21 Apr 2011 08:52
Thanks fellas. Mark, what's the picture in your new avatar?
2004 ZX-10R
Angola, IN
2004 ZX-10R
Angola, IN
- mark1122
- Keep twisting it
21 Apr 2011 09:02testarossa wrote: Thanks fellas. Mark, what's the picture in your new avatar?
that is the bigger badder version of plums av.
a crank support plate.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- testarossa
21 Apr 2011 09:24
Did you two collaborate on this avatar change? :whistle:
2004 ZX-10R
Angola, IN
2004 ZX-10R
Angola, IN
- mark1122
- Keep twisting it
21 Apr 2011 09:41testarossa wrote: Did you two collaborate on this avatar change? :whistle:
No i just 1 upped um. :laugh:
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
21 Apr 2011 09:53
josh,
excellent job on the carbs there man. :ohmy:
i knew you would not stop until they were just right,nicely done.
