Testarossa's 78 KZ1000 Fighter Build
- porchev914
Re: Testarossa's 78 KZ1000 Fighter Build
16 Mar 2010 08:25
I have a line on 2 sets of 08-09 ZX10R forks. One set is complete minus the top clamp. It is a natural finish anodizing with the black chrome coating on the slider. I like the silver uppers and black lower look
Another set is just the forks, brakes and tripple tree, but the the upper tree has already been drilled for handlebar risers :huh: Not sure who would do that mod then get rid of the forks, but its one less step for me!
FRANKEN Z!
- jayw704
16 Mar 2010 08:47
I just started reading your thread today wish I would have started when you started posting. I switched over to a 525 chain and sprockets and only have about 1/8" clearance but I and another poster earlier in the thread both have rigid rear ends so no chain movement... A bit more clearance may be required in your case.
1978 KZ1000
Go Loud and go fast or dont go at all!!!
- jayw704
16 Mar 2010 08:49
also on the rear set issue. I used the existing top mount bolt and mounted a new bolt above it for my zx7r rear sets it moved my legs back and away from the tank being that I am 6'2" and with the clip ons it gave me a much more comfortable seating position.
1978 KZ1000
- jayw704
16 Mar 2010 08:52 - 16 Mar 2010 08:55
sorry heres the shifter side. and I like the heel guards on the zx7r after I cut the old rear peg braces off the angle of the guard is exact to the line of the frame and I think looks good.
1978 KZ1000
Last edit: 16 Mar 2010 08:55 by jayw704.
- testarossa
16 Mar 2010 09:41
porchev914 wrote:
I'll have to check and see if there is any difference in length. 08-09 is third generation zx-10r, mine is first generation. Should be close. Those newer forks should look good on your bike. Mine have the gold anodized uppers and black lowers. Do you need to react soon to purchase the forks that you are looking at, or can it wait until I get to the house this evening?
I have a line on 2 sets of 08-09 ZX10R forks. One set is complete minus the top clamp. It is a natural finish anodizing with the black chrome coating on the slider. I like the silver uppers and black lower lookAnother set is just the forks, brakes and tripple tree, but the the upper tree has already been drilled for handlebar risers :huh: Not sure who would do that mod then get rid of the forks, but its one less step for me!
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
2004 ZX-10R
Angola, IN
- testarossa
16 Mar 2010 09:47
jayw704 wrote:
Thanks for joining in the fun Jay. You won't be punished for being late to the party.:laugh: I have some questions for you. How's the 525 chain holding up? It's the size on my zx-10r, and I would assume that if its strong enough for that, then it should stand up to the KZ. Also, I like your shifter set-up. Simple and elegant. I guess you have the motoGP style shift pattern now? 1 up and 4down.
2004 ZX-10R
Angola, IN
2004 ZX-10R
Angola, IN
- jayw704
16 Mar 2010 10:17 - 16 Mar 2010 10:26
My chain and sprockets are all from my 05 zx10r I did a 520 conversion on that and used the stock stuff. Holding up fine been on there about 3k miles. Original shift lever just cut short drilled a stud through and covered it with the rubber from the original it is gp style being that its backwards but I like it. You can use the linkage from the zx shifter but you just need to measure and make or buy a threaded shaft to fit the correct length between the linkage and the shift shaft at the side of the motor. heres the 10r
1978 KZ1000
Last edit: 16 Mar 2010 10:26 by jayw704.
- testarossa
16 Mar 2010 10:56
2004 ZX-10R
Angola, IN
2004 ZX-10R
Angola, IN
- jayw704
16 Mar 2010 12:03
Here's my favorite theft from my 10r when I switched to the integrated tail light I had the stock led just sitting in the box so some sanding and some jb weld later...
1978 KZ1000
- testarossa
16 Mar 2010 12:30
That fits pretty good. I a planning an integrated led for my kz, but I have yet to decide what to use. Are you running blinkers on your KZ?
2004 ZX-10R
Angola, IN
2004 ZX-10R
Angola, IN
- jayw704
16 Mar 2010 13:26
Nope hand signals only. have yet to find any that I actually like on the bike.
1978 KZ1000
- porchev914
16 Mar 2010 14:12 - 16 Mar 2010 14:30
It can wait until this evening. If I was in that much of a rush, I should be kicked in the arse for not planning ahead better
FRANKEN Z!
Last edit: 16 Mar 2010 14:30 by porchev914.
