Testarossa's 78 KZ1000 Fighter Build
  • mark1122
  • Keep twisting it
14 Dec 2010 15:03 #416946 by mark1122
Replied by mark1122 on topic Testarossa's 78 KZ1000 Fighter Build
testarossa wrote:
Adam, the holes in question are 3mm (0.118") diameter on 5mm (0.196") centers, and staggered.
that is the same thing i did to my Kerker. i was able to buy 1 of those baffles, and weld it to the Kerker end cap. mine is about 2 1/16" straight.
it works well for my 1200.
u may want to experiment. a smaller ID baffle will give u more bottom end if u feel u need it.
Nice job.on the baffle and the plastic welding.B)
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • testarossa
  • Topic Author
14 Dec 2010 19:31 #416987 by testarossa
Replied by testarossa on topic Testarossa's 78 KZ1000 Fighter Build
I actually suspect that the baffle is a little big for my setup, but I thought I would give it a shot. I used the smaller half of the original tube, so it tapers from 2" down to 1 15/16" IIRC.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
  • mark1122
  • Keep twisting it
16 Dec 2010 18:21 #417302 by mark1122
Dont forget to install a servo motor and butterfly valve for that added bottom end. :woohoo:
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • porchev914
16 Dec 2010 18:40 #417308 by porchev914
Replied by porchev914 on topic Testarossa's 78 KZ1000 Fighter Build
You mean one of these Mark?
I was wondering if it was worth the trouble to try and impliment it.....probably not since I can only drive it mechanically without an ECM.....
FRANKEN Z!
  • mark1122
  • Keep twisting it
16 Dec 2010 18:51 #417316 by mark1122
OH Yea baby, that's the 1.
just attach a bungy cord to the throttle and away u go.:woohoo:
wouldnt that be cool though if u could make it work.
Josh is ordering a throttle sensor for his 02 sensor. we'll have to get him to figure out how to tie the sensor to the exht.as well. :)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • testarossa
  • Topic Author
16 Dec 2010 20:36 #417339 by testarossa
Meh.
Everyone who has a sport bike is trying to eliminate that thing. I ain't wasting my time trying to add it.
As far as my little science project, I'm still waiting on one sensor. Finally got my electrical connector, and a throttle position sensor. Unfortunately, the postal service seems to be holding my MAP sensor hostage.
I probably won't have any test results for a little while. I went ahead and removed the tank for body work. I'm hoping to spray some paint the week after Christmas.
I decided to put the bike on my insurance policy today. I should be able to go get my plates tomorrow. Then I can go get my safety inspection once the bike is assembled enough to run. That way I will be able to conduct more thorough tests. As it is, with no tags, I'm not willing to venture out of my subdivision.
2004 ZX-10R
Angola, IN
17 Dec 2010 01:34 #417365 by sroberts152
Replied by sroberts152 on topic Testarossa's 78 KZ1000 Fighter Build
These guys make a great eliminator, BTW. I know this is for a Duc but if you chat with him and you are looking to clean up, he may be able to get something set up for you.
www.motocreations.com/electrical.asp
1978 KZ650SR
2001 Triumph Speed Triple i955
Past bikes - Too many to list.
23 Dec 2010 21:42 #418387 by Nelson
Replied by Nelson on topic Testarossa's 78 KZ1000 Fighter Build
Very nice plastic work! I suggest painting the vertical side parts of the fender a dif color than the top. To create some separation and emphasize the KZ look you're after.
I've made exhaust inner tubes from wire mesh many times. just roll a tube the size you want and wire it together. Then wrap with steel wool and glass. A bit crude, but you can't see it and I've been very pleased with the results on many bikes. You can tune the volume to your taste by changing the amount of packing.
Restoring and customizing a KZ1000. Click here to read about it.
Plated KTM, DR650, KZ1000, Former MC mechanic (eons ago). 40 yrs. of dirt and street.
  • testarossa
  • Topic Author
23 Dec 2010 22:23 #418390 by testarossa
Ya nailed it Nelson. I'm planning to paint the vertical elements of the fender black, and the horizontal part will match the blue in the rest of the body. I hope to show off some paint next week. Fighting the urge to get distracted by a certain Suzuki.
2004 ZX-10R
Angola, IN
  • testarossa
  • Topic Author
26 Dec 2010 17:04 #418697 by testarossa
Ok now I'm stuck at home watching the kids for the next week, and I'm broke from Christmas. I have no choice, but to get the bodywork done and paint the damn thing. I pulled off all the small parts that need paint and blasted them.
2004 ZX-10R
Angola, IN
  • testarossa
  • Topic Author
26 Dec 2010 17:05 #418698 by testarossa
I also got the last of the plastic bits sanded down. Here's the front fender:
2004 ZX-10R
Angola, IN
  • testarossa
  • Topic Author
26 Dec 2010 17:14 #418701 by testarossa
I also decided to fill in the cutouts on either side of the tail piece that would clear the upper shock mounts.
2004 ZX-10R
Angola, IN
