Testarossa's 78 KZ1000 Fighter Build
  • testarossa
  • Topic Author
04 Dec 2010 19:56 #415375 by testarossa
Replied by testarossa on topic Testarossa's 78 KZ1000 Fighter Build
Then I used a cutoff wheel in my dremel tool to cut the plastic close to the cut lines. I then filed the edge up to the line, and then sanded them smooth.
Now this fender does have two broken mount tabs that must be repaired. You can see the first in this picture.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
  • testarossa
  • Topic Author
04 Dec 2010 20:01 #415376 by testarossa
It just so happens that one of the scrap pieces removed from the fender has the same curve as the missing tab. I just made a cardboard template off the tab that is intact on the opposite side. Then cut the plastic piece. I cleaned up the edges of the fender where broken so that I would be attaching to straight lines, not jagged break lines. Then I just fusion welded the two pieces together using my soldering iron.
2004 ZX-10R
Angola, IN
  • testarossa
  • Topic Author
04 Dec 2010 20:04 #415377 by testarossa
Now I have some ABS plastic rods from another repair, so I use them as a filler rod. Make sure that there is enough material there to sand back to the finished profile.
2004 ZX-10R
Angola, IN
  • testarossa
  • Topic Author
04 Dec 2010 20:08 #415378 by testarossa
Now, I still need to do a little work around the screw hole to make it match the other side, but I have it close. These type of repairs are not perfect. There are usually quite a bit of pinholes to fill before you paint the repair.
2004 ZX-10R
Angola, IN
  • testarossa
  • Topic Author
04 Dec 2010 20:09 #415379 by testarossa
I guess you might want to see the fender after I cut it. I almost forgot to take this picture.
2004 ZX-10R
Angola, IN
  • testarossa
  • Topic Author
04 Dec 2010 20:12 #415380 by testarossa
I will probably paint the fender black to minimize it's appearance. At the very least, the sides will be black. I really like the look of no fender, but it's not very practical.
2004 ZX-10R
Angola, IN
  • testarossa
  • Topic Author
04 Dec 2010 20:15 #415381 by testarossa
porchev914 wrote:
Just an FYI on the tank- even a straight tank will have high spots/low spots and slight waves in the sheetmetal. If you were going for a pro job you would skim coat the whole tank to fill in all the slightly low spots to make it perfect ;)
Good point Adam. I'll probably do just that. I want it to look as good as I can get it.
2004 ZX-10R
Angola, IN
  • porchev914
04 Dec 2010 20:49 #415387 by porchev914
Replied by porchev914 on topic Testarossa's 78 KZ1000 Fighter Build
It looks good, I like it.
FRANKEN Z!
  • DoubleDub
  • Visitor
04 Dec 2010 21:59 #415396 by DoubleDub
Replied by DoubleDub on topic Testarossa's 78 KZ1000 Fighter Build
Boy, does this bring back memories of my side cover repairs....looking good!
  • testarossa
  • Topic Author
04 Dec 2010 22:02 #415397 by testarossa
Did you have some cracks around the mounting tabs?
2004 ZX-10R
Angola, IN
  • DoubleDub
  • Visitor
04 Dec 2010 22:06 #415399 by DoubleDub
I actually had the usual flex crack in the side cover. About 2/3 of the way up the front side of the side cover. Similar repair, although I didn't have any ABS filler rods - had to smooth it out and paint. Still a bit of a ridge even after primer and paint, but hard to see.
  • testarossa
  • Topic Author
04 Dec 2010 22:27 #415400 by testarossa
I guess I'm lucky to work in a machine shop. If we need material, it just gets lumped in with a daily order. 1/4" ABS barstock, no problem. Before I had the barstock, I had an old KZ750 tail piece that I would cut chunks off to use as filler. Most model kits are made from ABS, you can use the spars that the pieces are attached to.
2004 ZX-10R
Angola, IN
