Testarossa's 78 KZ1000 Fighter Build
- testarossa
Re: Testarossa's 78 KZ1000 Fighter Build
12 Oct 2010 04:17
Leon you're right. You have to remove the subframe connectors to get the exhaust out, so that you can get the powertrain connector out, so you can get the driveshaft out etc, etc, etc. I already have the bellhousing bolts out, and still can't get the tranny out since I left the link pipe from the header to the catalityc converter in.
TexasKZ, I would be tempted to do that to the car if it were mine, but mama wouldn't have it. Actually I would probably turbo it first, but an LS1 would sure sound cool in that little car.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
2004 ZX-10R
Angola, IN
- mark1122
- Keep twisting it
12 Oct 2010 07:19
testarossa wrote:
if u had the fuel screws at 1 1/4 turn , they may be ok. if u think it is still rich at 1 1/4, just turn them in more. u dont change the jet unless u run out of screw travel, or close to it.
i would drop the needle before a pilot change too, just to see if it helps. the needle will overlap the top end of the pilot circuit.
good luck.
jus1975 wrote:i wish i would have saw this before you started on that tank. you should not start at the center but at the outside edges then work your way inward. it works out better and less repair afterwards
That's a good tip. It's no matter, the remainder of the dent will be corrected with filler. I just didn't want filler that was 1/4" deep. I'll keep that one in mind for the next time I pull a dent.
Mark, the screws were at 1 1/4 turns out from seated. I have the screws that are on the engine side of the carb. I suspect that this will change with the smaller jets. I doubt that I can fool with it today. I'm committed to catching up on car maintenance. Oil changes all around, and sadly the Miata needs a throwout bearing.
good luck.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- testarossa
12 Oct 2010 07:28
mark1122 wrote:
I guess that I will learn this one the hard way. I already changed the pilots. I'll try with the 17.5s since they are already in there. I'll know about the pilots right away if I have to set the screws at 3 turns out. It's going to be tough to find the time for testing in the next two weeks.
testarossa wrote:jus1975 wrote:i wish i would have saw this before you started on that tank. you should not start at the center but at the outside edges then work your way inward. it works out better and less repair afterwards
good luck.
2004 ZX-10R
Angola, IN
2004 ZX-10R
Angola, IN
- Tony
Author
- trianglelaguna
12 Oct 2010 07:53
sounds good in the clip...i like the dirt bike bars and stock looking guage location...and the painted stripe too.....cool.........closaaaaa
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
- tk11b40
12 Oct 2010 19:43
That is too cool I just watched the video....
NICE WORK!!
NICE WORK!!
Suzuki GSXR 750 slabside
Ducati S4R
Husqvarna FE 350s
Ducati S4R
Husqvarna FE 350s
- tk11b40
12 Oct 2010 19:48
I have more questions??
How do you plan on adapting the old KZ speedo to the new front tire/wheel combination?
Can you adapt? I think one of the styling highlights of the KZ is the gage pack. If you can just adapt somehow, then it would mean I can use the old style gages on the KZ I am building.
They are like a signature of the KZ, I really want to use them.
your thread is very detailed and informative Thank you for sharing!!
Ducati S4R
Husqvarna FE 350s
Ducati S4R
Husqvarna FE 350s
- testarossa
12 Oct 2010 20:32
tk11b40 wrote:
I fully agree about the gauges. I'm working on that one at the moment. You know I'll post any info that I discover. Lord knows that I scratched my head long enough to figure out how to mount the gauges to the GSXR top clamp. I have to at least try and make them work. I should have kept the GSXR dashboard. I bet that I could have hidden the guts of the Suzuki speedo behind the KZ gauge face and made something work. Hmmmm....
2004 ZX-10R
Angola, IN
2004 ZX-10R
Angola, IN
- Nelson
12 Oct 2010 20:49
maybe buy a little GPS unit and stick it inside the KZ guage housing.. ? frame it with a little CF plate. just brainstorming. or a bicycle speedo?:huh:
Restoring and customizing a KZ1000. Click here to read about it.
Plated KTM, DR650, KZ1000, Former MC mechanic (eons ago). 40 yrs. of dirt and street.
- testarossa
13 Oct 2010 19:56
Excellent suggestion Nelson. I have a spare bike speedo that I could use in a pinch.
I actually started a discussion about this subject here: kzrider.com/index.php?option=com_kunena&...ew&catid=4&id=405926
Feel free to chime in there with any more suggestions. I'm all ears at this point. No idea is too crazy.
2004 ZX-10R
Angola, IN
2004 ZX-10R
Angola, IN
- testarossa
20 Oct 2010 18:24
A small update since I actually got a little time to work on the bike today. I got the shifter actually connected to the DIY rearsets this evening. Kinda tricky to route the connecting rod without hitting the side stand.
Well I found the idiot light cover that fell off when I was lapping the subdivision. Unfortunately I found it on top of the head.
After I experimented a little with the 17.5 pilots, I have discovered that the 20s were right in the first place. I can't even get the bike to idle without being on the choke with the 17.5s in place. I tried everything from 1 to 3 turns out on the pilot screws. Mark was right, as usual. Maybe, I'll have time to correct it on Friday.
2004 ZX-10R
Angola, IN
2004 ZX-10R
Angola, IN
- porchev914
20 Oct 2010 22:01 - 21 Oct 2010 06:34
That sucks about the indicator lamp cover. I don't think it will be to difficult to find a replacement. Mine was gone when I bought the bike..along with smashed gauges. I think I spent $50 on a replacement gauge cluster including the indicator lamp assembly off ebay. Just getting the cover should be cheap and easy. Good luck on the jetting, I'm suprised you need to vary much from the stock baseline with a stock engine. I wanna work on my bike, but a buddy invited me to a moto track and I haven't ridden since I had my ACL surgury. I think I need a little adrenaline to boost my bike building drive
FRANKEN Z!
Last edit: 21 Oct 2010 06:34 by porchev914.
