1977 z650b1 project with pics [completed!!!]
- Kawickrice
Re: 1977 z650b1 project with pics-need help!
05 Nov 2009 10:07
The rectifier I have has Mitsubishi DS10TR2-M C9Y written on a sticker. C9Y looks to be a date code but I am not sure
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- OnkelB
05 Nov 2009 10:08 - 05 Nov 2009 10:13
That's the same rectifier that was on my 77 650 B1 when I got it, ran and charged perfectly for 5 years before I swapped engines and went with a permanent magnet setup.
You're probably right that it's a date code or maybe a batch no., mine is marked C06.
77 KZ 650 B1, 82 GPz 1100 B2.
Last edit: 05 Nov 2009 10:13 by OnkelB.
- Kawickrice
05 Nov 2009 10:12 - 05 Nov 2009 10:20
So you are saying the rec I have will work with both bikes as long as they are 3 phase regardless of permanent magnet or excited field?
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
Last edit: 05 Nov 2009 10:20 by Kawickrice.
- OnkelB
05 Nov 2009 10:15
I think they will - I'll ask Lou to check this thread, he knows what he's talking about.
- loudhvx
05 Nov 2009 18:26
Yes, the 900 with seperate reg and rec can use the same rectifier as the 77 650 which also has the seperate reg and rec, even though their regulators are completely different as detailed by OnkelB.
The 900, even though it originally had seperate reg and rec can use most modern 3-phase reg/recs from bikes with 3-phase, permanent-magnet alternators. There are also many aftermarket combo reg/recs which will work.
The 77 650, unfortunately, has to retain seperate reg and rec since there is no combo unit for this setup (that I know of). Oregonmotorcycleparts.com has a reg specifically for the 77 650 and the ones I've dealt with seem pretty good, especially if you consider how affordable they are.
You can make just the rectifier pretty easily.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- cobura
- forever 2 wheels
08 Nov 2009 16:56
Wow thanks for all the info everyone! This has really encourage me to do a lot of studying.
So basically, we have reached the conclusion that on a z900, which is permanent mag setup, you can use any rect as long as it is 3 phase. My question: Does that also apply to my 650? Can I use any rect as long as it is 3 phase? Since my new reg/rect is a combo, does that mean i cant use it at all? Would i be able to just ignore some of its wires and use it in conjunction with my old reg.?
1979 KZ650B3
- Kawickrice
08 Nov 2009 17:52
It sounds like the 650 will take the same rec that the 900 uses but the 650 has to have its own regulator for that bike. The combo unit will NOT work on the 650. I think that is what was said
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- loudhvx
09 Nov 2009 07:24 - 09 Nov 2009 07:28
Yes, both 900 and 650 can use any 3-phase rectifier, as long as they are using a seperate regulator.
Usually, you would not use a combo rec/reg just for the rectifier portion. However, there is small chance you can use it as just a rectifier. If the combo rec/reg uses a dedicated sense line to detect voltage, you could leave that wire disconnected (or possibly ground it). Then it will never do any regulating, but will still rectify.
If the combo unit has no dedicated sense line, and, thus, senses battery voltage through it's output wire, there is no way to disable the regulator. You would not be able to use this type for rectifier-only duty.
Since your new reg/rec has that extra brown wire (assuming it uses KZ color convention), there is a chance you can use it as just a rectifier.
Do you have any literature or instructions on the reg/rec unit you bought?
1981 KZ550 D1 gpz.
Other links.
Other links.
Last edit: 09 Nov 2009 07:28 by loudhvx.
- cobura
- forever 2 wheels
20 Nov 2009 06:14
Thank you to all for the help. I really learned a lot about rectifier. I think i figured mine out, but not sure. I need to get the carbs finished so that i cant start the engine and test it.
*******Does anyone know what the stock jet sizes are for this bike? (1977 z650b1) Although it is the japanese model, i think it has the same carbs as shown in the pictures above. They are the round type Mikuni brand. My original jets are so corroded that i cant make out the number on any of them.
1979 KZ650B3
- OnkelB
20 Nov 2009 06:26
#15 pilots, #102.5 mains, needle clip in the 4th groove (counting from the blunt end of the needle) is the stock setup.
- Qdude
- It is all good.
23 Nov 2009 18:15
Just a note here, that rectifier was a breeze to build.
77 KZ 650 C1.
77 KZ 650 C1.
77 KZ 650 C1.
- cobura
- forever 2 wheels
25 Nov 2009 18:00
Qdude wrote:
-care to elaborate?
-care to elaborate?
1979 KZ650B3
