1966 Kawasaki A1 Samurai restoration project 08 Jul 2012 03:59 #534603
  • larspjac
  • larspjac's Avatar
  • Thank you received: 0
Hi. I am starting a new project with an A1 vin. no. 11156 (67) Denmark.
How did you optain the pattern for the expansion chambers, or where did you buy
those blanks unfinished pipes.
Hope you can help me,
Lars.
This email address is being protected from spambots. You need JavaScript enabled to view it.
1966 Kawasaki A1 Samurai restoration project 04 Feb 2013 02:05 #570679
  • 68Craftsman
  • 68Craftsman's Avatar
Hello Clutch.
Just wanted to say hello and inquire about how your project is doing? I just picked up a 68 A1 Samurai that has been stored for 32 years. Looks to be in pretty good shape but will certainly need a fair bit of for before it runs again. I have been doing lots of research online and came across this thread the other night. Your documentation of the restoration of your '66 is fantastic and will be a huge help when it comes time to do all the same stuff to mine. Thank-you!! I just signed up for this site so I could e-mail and ask you how it turned out..... I was also curious about the carb job - looks like you were about to start into that when the posts trailed off.... Hope it turned out ok.
Anyway, would be great to connect with you as I probably have all the same questions that you had when you were starting (plus this is my first bike restoration).
Thanks,
68Craftsman
1966 Kawasaki A1 Samurai restoration project 14 Feb 2013 22:02 #572423
  • clutch
  • clutch's Avatar Topic Author
  • I wish I had a tad more patience to do it better!
  • Thank you received: 12
@68Crafstman
Well I haven't had much free time to work on the project over the last year. It pretty much sits in the garage as I left it. I do plan to get back in there and finish it this spring, so once it starts warming up here in MD a bit, you should see some new posts on here from me.
Southern Maryland, USA
1980 KZ250 LTD (traded, but still missed)
1982 KZ750 E3 (Cafe Project) (Dyna-S, Dyna Coils, V&H 4-1, K&N Pods, 6 Sigma Jet Kit, Acewell Computer, Woodcraft Clip-ons, Custom Rewire)
1966 A1 Samurai (Restoration Project)
Wish List:
KZ1000 P (For a "touring" bike)
Z1 (need I...
1966 Kawasaki A1 Samurai restoration project 25 Jul 2013 03:21 #598171
  • clutch
Finally back in the garage tonight working on this project again. I put the bottom end back in and threw the new piston rings on. I was going to reinstall the cylinders and heads, but ran into an issue getting the pistons in there without a piston ring compressor tool. Guess I will be making a trip to autozone tomorrow to see if they stock those. More pics coming soon :)
Wish List:
Z1 (need I...
1966 Kawasaki A1 Samurai restoration project 25 Jul 2013 09:11 #598182
  • Thank you received: 2098
Might be feasible to fashion a ring compressor with a strip of thin metal -- such as a short length of metal tie wrap -- bound tightly over the piston rings with a plastic tie wrap, so that inserting the piston into the cylinder bore pushes the metal strip and plastic tie wrap downward onto the piston skirt, from where they are removed (being careful not to drop either of them into the crankcase).
When in position, ends of the metal strip should not overlap.
Good Fortune! :)
Last edit: by Patton.
1966 Kawasaki A1 Samurai restoration project 25 Jul 2013 10:57 #598192
  • clutch
Well fingers worked fine after realizing that I didn't have them lined up with the pin. The bad thing is I had them on upside down and broke one removing it. I got one cylinder and head back on, but the other now is waiting for parts again. Live and learn... :/
Wish List:
Z1 (need I...
1966 Kawasaki A1 Samurai restoration project 25 Jul 2013 18:03 #598242
  • kzcurt
  • kzcurt's Avatar
  • Thank you received: 21
where's bike today?
Flag carrier #23
9 @ 50-2053,
1966 Kawasaki A1 Samurai restoration project 25 Jul 2013 18:44 #598252
  • ed spangler
  • ed spangler's Avatar
  • Tennessee Z
  • Thank you received: 29
43?? :huh: . Hmmm.... maybe 47!? Darn near 50 if ya think about it! :woohoo: Way Cool!! :woohoo: B)
Anyway, ITS an AWESOME looking project!!
Step by step pics of ongoing project? ( we hope!)
TennesseeZ ED
Have 1975 Kawasaki Z1-B & 2003 Harley Davidson Heritage Softail Classic
Had Hondas, Harleys and many ,many Z Series Kaws both Std. & LTD's
1966 Kawasaki A1 Samurai restoration project 27 Jul 2013 17:08 #598584
  • clutch
Back into the garage again today. I reinstalled the right side valve cover, clutch, and threw on the generator temporarily to ensure all timing marks are lined up properly. Here's a pic showing the motor back in the bike with the right side nearly done and one cylinder an head reinstalled:
Wish List:
Z1 (need I...
