750 cafe racer
- thompsonmx100
       Topic Author Topic Author
Re: 750 cafe racer
28 Nov 2009 18:27
    Oh so you used the same paint just different color.Is it holding up well? I used ppg grease and wax remover on all the pieces. I seem to have pretty good adhesion.
      2006 gs 500 streetfighter
1982 gpz750 breathed on wreck
1985 gpz750
Kz 650
1985 gpz750
Kz 650
- mark1122
- Keep twisting it
Re: 750 cafe racer
28 Nov 2009 19:07
    Yes it's holding up just fine. the beauty of this is u can just spray a dab of touch up if u need too.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Bad Kaw
- Flying Squirell
Re: 750 cafe racer
30 Nov 2009 20:11
    mark1122 wrote:
Yep!
      VERY NICE!!
Yep!
      78 Kawasaki Z1R
81 Kawasaki KZ1000J (mods)
70 Kawasaki KV75
83 Honda CB1100F (few mods)
70 Kawasaki KV75
- thompsonmx100
Re: 750 cafe racer
01 Dec 2009 17:15
    Thanks I have it torn down again I'm gonna finish the frame this week then that will be done. Still need to get the subframe welded up. Just trying to get cheap stuff out of the way so i can save some money for the motor bits. It's coming along pretty quickly. I am having trouble staying busy I just have all these loose ends that kinda overlap each other so it's tough trying to just get things finished.
Peace
Travis
      Peace
Travis
1985 gpz750
Kz 650
1985 gpz750
Kz 650
- thompsonmx100
Re: 750 cafe racer
09 Dec 2009 17:49
    well I reblasted my upper cases and tried to paint them tonight but the weather was messing with the paint I'll try again this weekend. So I moved on to mounting my rearsets. I have them half mounted I just drilled a hole then welded a nut over the top. the bottom will have a threaded plate made and welded to the frame. but heres some pics of it.
1985 gpz750
Kz 650
1985 gpz750
Kz 650
- Gomer
- I crap worms that look like spaghetti
Re: 750 cafe racer
09 Dec 2009 19:18
    The metal you used for the structure under the seat; square tube? What specifically?
    ماذا تعني لا العذارى؟
(What do you mean 'no virgins'?)
- thompsonmx100
Re: 750 cafe racer
09 Dec 2009 19:23
    Its an aluminum cr 250 subframe
1985 gpz750
Kz 650
1985 gpz750
Kz 650
- Gomer
Re: 750 cafe racer
09 Dec 2009 19:27
    Holding the seat up?
- thompsonmx100
Re: 750 cafe racer
09 Dec 2009 19:44
    yep it is plenty strong I will relocate the battery to under the seat itself. It is bolted to the back of the frame.
1985 gpz750
Kz 650
1985 gpz750
Kz 650
- thompsonmx100
Re: 750 cafe racer
15 Dec 2009 17:53
    well I finished mounting the rearsets and made a tab for the brake res. What do you guys think about the heel guard? I am considering ditching them or making new smaller ones with speed holes drilled into them.
1985 gpz750
Kz 650
1985 gpz750
Kz 650
- thompsonmx100
Re: 750 cafe racer
04 Jan 2010 20:14
1985 gpz750
Kz 650
1985 gpz750
Kz 650
- TerryK
Re: 750 cafe racer
10 Jan 2010 17:37
    Looking good!
That aluminum removable subframe is a great idea. nice work!
      1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
