750 cafe racer
- thompsonmx100
       Topic Author Topic Author
Re: 750 cafe racer
28 Aug 2009 16:20
    I got a new job today so work can commence on the bike. I will probably press the stem when i go to pick up my box on Monday. Then it will be some cutting and welding (have to work on my welding skills)
      2006 gs 500 streetfighter
1982 gpz750 breathed on wreck
1985 gpz750
Kz 650
1985 gpz750
Kz 650
- PLUMMEN
Re: 750 cafe racer
28 Aug 2009 16:42
    looking good so far
- thompsonmx100
Re: 750 cafe racer
01 Sep 2009 18:17
    Made some progress since I have a job again I have access to a press again so I Got the stem press together. I will take some pics of that when I take it back aprt to put the locking bolt in it. I then sat the bike on the ground and set the tank where I wanted it angle and center wise same with the seat. Then I got to sit on it and make bike noises.
Does anyone have a zx7 or 9 speedo drive they would like to get rid of. I need one to make the frontend complete.
1985 gpz750
Kz 650
1985 gpz750
Kz 650
- TerryK
Re: 750 cafe racer
01 Sep 2009 19:57
    Hey that thing's going to look badass!! Nice work.
      1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
- thompsonmx100
Re: 750 cafe racer
14 Sep 2009 17:36
    I have added a new shock to replace the pos gpz shock. I found with the new forks being shorter that I need to lower the rear end some. So I did some research and found that an 06 Yam r6 shock was a good match. Its got all kinds of turny things :laugh:
1985 gpz750
Kz 650
1985 gpz750
Kz 650
- thompsonmx100
Re: 750 cafe racer
14 Sep 2009 17:40
 and ive also began making a rear hugger from an old 82 gpz tail section. I thought it would kinda carry on the new school old school theme. And it would solve a problem for free. as I'm going for a open look with velocity stacks I didn't want the tire to kick something into the carbs.
1985 gpz750
Kz 650
1985 gpz750
Kz 650
- Bad Kaw
- Flying Squirell
Re: 750 cafe racer
14 Sep 2009 18:32
    I couldn't see where you were going with this at first ... but now it's coming through.  Pretty cool.  Nice work.
-KR
      -KR
      78 Kawasaki Z1R
81 Kawasaki KZ1000J (mods)
70 Kawasaki KV75
83 Honda CB1100F (few mods)
70 Kawasaki KV75
- thompsonmx100
Re: 750 cafe racer
14 Sep 2009 19:00
    Yeah I hope to pull it off with the finishing touchs and the paint.
1985 gpz750
Kz 650
1985 gpz750
Kz 650
- galaxian
Re: 750 cafe racer
16 Sep 2009 07:38
    how about more info on the swingarm year of it specifically. Also what did you do to make the swingarm fit besides the engine clearance issue that you are having?
      1977 KZ1000A1, 1979 KZ650 C3
- thompsonmx100
Re: 750 cafe racer
16 Sep 2009 18:10
    this is a 2005 gsxr 600/750 swing arm. I only have to get some shims for the pivot side to side. I took the inner sleeve out of my gpz swingarm pivot and it slides right into the gsxr pivot then you use the stock pivot bolt. The shims that I need are factory gsxr shims. There are 1 on each side stock, in order to make it work in the gpz frame you need 3 on each side. Then I used the stock gpz rocker and mounted the R6 shock to even out the stance. I did have to make a couple of spacers for the rocker too.
1985 gpz750
Kz 650
1985 gpz750
Kz 650
- thompsonmx100
Re: 750 cafe racer
01 Oct 2009 16:47
    well I have been doing a little bit here and there. I have the front tank mounts installed. To do this I took a bolt cut the head and the threads off and welded 2 washers to each end then welded the whole assembly to the frame. Not the prettiest welds but I had the engine in it kinda tight. It aint goin anywhere. :laugh: :huh:
1985 gpz750
Kz 650
1985 gpz750
Kz 650
- thompsonmx100
Re: 750 cafe racer
01 Oct 2009 16:49
    I also had to pinch the frame to allow clearance for the tank. Then I disassembled the bike and began cutting off brackets that I had not cut off yet.
1985 gpz750
Kz 650
1985 gpz750
Kz 650
