750 cafe racer
- thompsonmx100
Re: 750 cafe racer
02 Aug 2009 19:36
Thanks thats what i did. I took a little off the back of the engine and and a little off the swingarm and voila it fit. Now I'm concernd about the bottom linkage and where its supposed to mount. I won't know for sure until i mount the top of the shock I may try to take a little off of it tomarrow and get it mounted then see if i can mount the linkage. I also started to mount the tank. I will need to bang out the inside of it to make it fit over the frame. Got a little late to finish.
2006 gs 500 streetfighter
1982 gpz750 breathed on wreck
1985 gpz750
Kz 650
1985 gpz750
Kz 650
- thompsonmx100
Re: 750 cafe racer
07 Aug 2009 17:40
Well I took some photos today. I have removed some brackets that will never be used again, I beat the inside of the tank to fit over the backbone, And I have mounted the gsxr swingarm. I used the stock shock and rocker It feels alright a little soft might be the shock or a combo of soft shock and longer swinger. Front still needs to be finished. But I was able to actually sit on it.
1985 gpz750
Kz 650
1985 gpz750
Kz 650
- thompsonmx100
Re: 750 cafe racer
07 Aug 2009 17:41
1985 gpz750
Kz 650
1985 gpz750
Kz 650
- thompsonmx100
Re: 750 cafe racer
07 Aug 2009 17:41
1985 gpz750
Kz 650
1985 gpz750
Kz 650
- TerryK
Re: 750 cafe racer
07 Aug 2009 18:06
That's a cool looking project! Question: why are you not using the gixer shock and linkage?
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
- KawiConvert
Re: 750 cafe racer
07 Aug 2009 18:55
Looking good. I like the CX tank, I tried one on my KZ but like yours it didn't quite fit right and I ended up with the one I have now kinda by chance. Still the CX has a nice line to it.
1978 KZ650 D1 ~ Carb jetting: 107.5 & 20 & 4th groove with pods and 4-1 Exhaust
- thompsonmx100
Re: 750 cafe racer
07 Aug 2009 20:08
Thanks gents the tank is nice very retro cafe without the price. I heated up the tunnel with a torch and hammered it into itself creating enough room for the backbones. damn semi perimeter frames. It actually turned out pretty good. not super pretty but good. to answer the question about the shock and linkage the shock is an inch longer than the stocker and the rocker or linkage is too short I couldn't reach the frame. so with the stock linkage and shock its like I just added a stretched swingarm. Also the top shock mount was too wide for the frame. I will probably end up swaping shocks for something similar to gsxr shock but shorter and a proper spring rate. It is cool going out into the garage with a cold one and seeing it sitting on the stand
1985 gpz750
Kz 650
1985 gpz750
Kz 650
- thompsonmx100
Re: 750 cafe racer
08 Aug 2009 23:08
I started the stem swap today. Looks like I'll be able to use the zx7 stem and just press the gpz stem into it. Using the zx7 stem as a bushing. I have my gpz stem in the freezer right now. hoping to be able the just slip the two together using heat and cold. If it works I'll have the front end together tomarrow and I'll post some pics.
1985 gpz750
Kz 650
1985 gpz750
Kz 650
- thompsonmx100
Re: 750 cafe racer
19 Aug 2009 19:30
I haven't done much lately I took apart the rearend and took some pics of the modifying that I had to do to make the swingarm clear.
1985 gpz750
Kz 650
1985 gpz750
Kz 650
- thompsonmx100
Re: 750 cafe racer
19 Aug 2009 19:30
1985 gpz750
Kz 650
1985 gpz750
Kz 650
- thompsonmx100
Re: 750 cafe racer
19 Aug 2009 19:31
1985 gpz750
Kz 650
1985 gpz750
Kz 650
- thompsonmx100
Re: 750 cafe racer
19 Aug 2009 19:33
1985 gpz750
Kz 650
1985 gpz750
Kz 650
