"1979 MKII Road Race Bike"
- Captaingamez
19 Apr 2009 00:00
I have decided to turn my MKII into a total race bike on the road.
I got my front end put together yesterday. zx11 forks/wheel on 89' zx7 clamps.
I need to find a ZRX swingarm.
Any suggestions?
Any suggestions?
1979 Kz1000 MKII road racer project
1994 Seca II, pile in the corner
1973 Honda cb175 cafe racer
1971 Yamaha AT1
1975 Massey Fergusson MF440
1971 Skiroule 300rr
1971 Yamaha AT1
1971 Skiroule 300rr
- parkingpuckguy
Re: "1979 MKII Road Race Bike"
19 Apr 2009 06:16
There's a couple for sale on the ZRXOA forum. That's where I got mine.
- Calhoun
- Hayabusa= I ride to the strip club in flip flops
19 Apr 2009 06:29
Hey nifty bike! I wish mine had looked like that. I am modifying an 80' MKII. It came with a 78' tank and body work.I just finished putting a ZRX swing arm on it.
80 IT175, 84 XL200, XT250, 95 ST1100 96 xr650l (30k miles),kz1000, KX250 97'
Last and most important 93 KX500.
- Captaingamez
19 Apr 2009 10:48
sweet, im gonna check ZRXOA for the swingarm. but where can i get the steering stem bearings to put this front end on?
1971 Yamaha AT1
1971 Skiroule 300rr
1971 Yamaha AT1
1971 Skiroule 300rr
- Calhoun
19 Apr 2009 16:00
So you want to use a zx7 triple clamp and stem, right?
If you know the inside diameter the the zx and the outside for the kz you may be able to do that.
A few of us have cut the zx stem off leaving the unseen part in the lower clamp. The kz stem is then machined, and pressed down inside the remaining piece of zx stem. Throw in a set of new KZ bearings and you are almost done.
- Captaingamez
14 May 2009 11:05
Stripped down the KZ this weekend for frame strengthening, new engine gaskets from Z1E, and trying to mount up my new ZX11 front suspension.
are there any tapered roller bearings available for the kzs or am i stuck with loose balls (giggity giggity giggity)
1971 Yamaha AT1
1971 Skiroule 300rr
1971 Yamaha AT1
1971 Skiroule 300rr
- Jack
14 May 2009 11:34
Tapered bearings are avialble for the KZ1000 MKll- I've got them in both of mine. Cutting the stem and welding to your existing lower tree is pretty easy -I put a set of KH400 2 stroke trees on my dragbike and had the KZ stem fitted and welded to the lower tree.
79 KZ 1075 MKll
79 KZ 1500 MKll dragbike
Gone but not forgotten:
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
- Captaingamez
28 Jun 2009 21:18 - 28 Jun 2009 21:31
just finished figuring out some of the dificulties of the rear end setup im planning on using. Its a GS1100 aluminum swingarm. with a ZX9 rear wheel and 160 tire. the setup has been centered in the swingarm. I had to Machine down the sprocket carrier in two places to make it run in the center, on the sprocket surface and on the very outside of the sprocket carrier bearing. but i seem to have plenty of chain room with this setup.
1971 Yamaha AT1
1971 Skiroule 300rr
1971 Yamaha AT1
1971 Skiroule 300rr
Last edit: 28 Jun 2009 21:31 by Captaingamez. Reason: pic
- Captaingamez
29 Jun 2009 10:49 - 29 Jun 2009 10:51
1971 Yamaha AT1
1971 Skiroule 300rr
1971 Yamaha AT1
1971 Skiroule 300rr
Last edit: 29 Jun 2009 10:51 by Captaingamez.
- Captaingamez
29 Jun 2009 10:53
1971 Yamaha AT1
1971 Skiroule 300rr
1971 Yamaha AT1
1971 Skiroule 300rr
- Captaingamez
29 Jun 2009 10:55
You can see the lack of room on the outside of the sprocket carrier, but the adjusters do clear it now. and the tire rides center.
1971 Yamaha AT1
1971 Skiroule 300rr
1971 Yamaha AT1
1971 Skiroule 300rr
- Captaingamez
29 Jun 2009 11:03
This is a pic of the brake setup im planning on using. It' s off of an R6.
Does anyone see any problem with cutting off the original mount bolt slot for the caliper mount (which stock, mounts direct to the swingfarm) and drilling a hole in it for a differant torque arm?
1971 Yamaha AT1
1971 Skiroule 300rr
1971 Yamaha AT1
1971 Skiroule 300rr
