1975 KZ 900 , ZRX Swingarm, 89 GSXR front end
- tk11b40
Re: 1975 KZ 900 , ZRX Swingarm, 89 GSXR front end
14 May 2013 01:07Well...
Long time since last report. First the bike is still alive, I have not drug it down the street behind my pick-up truck. This is good.
I got it back from the shop in Reno (protective custody foster home for a year), and started it. Number 4 cylinder is not firing. I took the carbs off, and cleaned them. The needle and seat was stuck closed in #4. Put it back together, still no luck; but when the mains kick in it roars. I think the float level is too low on that carb, so the pilot is not getting fuel. more tinkering.
Meanwhile the Neighbor who owns the Gixxer I am restoring insisted on having the KZ paint "tuned'. The bike was solid orange, and graphically challenged.
"Gary" put some stripes on for me, and re-clear coated it. WOW !! The bike now has show quality paint. We got the title straightend out, so it is ready for the road.
I think I will end up with a new set of flatslides eventually but it is now riding season, which normally eats up the cash (track days and travel). Any way when it hits the mains at about half throttle it really sings, so this is a good sign.
I now owe Neighbor a ton of time, the paint is soooo nice it must have been expensive..but nobody is talking. The painter will not tell me, nor will neighbor. Gotta get more work done on the gixxer.
Here are a couple photo's of the paint.
Suzuki GSXR 750 slabside
Ducati S4R
Husqvarna FE 350s
Ducati S4R
Husqvarna FE 350s
- tk11b40
14 May 2013 02:06
Ducati S4R
Husqvarna FE 350s
Ducati S4R
Husqvarna FE 350s
- Harvey1327
14 May 2013 06:16
In one word. WOW!!!!!!!
1 x 77 Z1000
1080,cams,ported
29 smoothbores,
Akron rims,Martin Swingarm
1 x 77 Z1000
1327 Wiseco,cams
ported,34.5 S/bores
GSXR swingarm
RF900 frontend.
1 x 2008 Nightrain
shotgun shock,corbin
seat,fat bars,some bling.
www.kzrider.com/media/kunena/attachments/8119/IMG_0461.JPG
1080,cams,ported
29 smoothbores,
1 x 77 Z1000
1327 Wiseco,cams
ported,34.5 S/bores
GSXR swingarm
RF900 frontend.
1 x 2008 Nightrain
- 79MKII
- Love Them Kaws!
14 May 2013 09:09
Wow :ohmy: Beautiful!! The whole bike looks fantastic!!
The Kaw List:
14 May 2013 09:40
The following user(s) said Thank You: tk11b40
- testarossa
14 May 2013 10:30What he said.
I like the off center stripe. I even considered that for my bike.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
2004 ZX-10R
Angola, IN
- gengomerpyle
14 May 2013 15:07
wow that looks great, but then again it looked great before
tk11b40 wrote:
Well...
1982 GPZ750R1 ELR
1978 Honda CB750F SuperSport
1971 Honda CB750K
1970 Honda CL100 Scrambler
1971 Honda CB750K
- CruisingRam
14 May 2013 16:46
top shelf there!
1975 Z1 B 900- soon to be heavily modded
Pahoa, Hawaii is my new hom
I am working hard to save up the shipping money to get my shop opened here in Hawaii
I hate electrical stuff.
- tk11b40
14 May 2013 23:41
Thank you all... Especially neighbor..who remains annonimus due to the nature of his wrk.
We call him S-2.
We call him S-2.
Ducati S4R
Husqvarna FE 350s
Ducati S4R
Husqvarna FE 350s
- homert1
05 Jun 2013 14:31
Your bike looks awesome!! This is exactly what I plan to do with my KZ900.....only more factory paint scheme. How hard was it to adapt ZRX swingarm and GSXR fork? I've read many posts here and seems relatively straight forward but any advice would be greatly appreciated.
AGAIN.......nice bike!!
- tk11b40
06 Jun 2013 00:22
Thank you for the compliment!!
The hardest part of installing the new suspension was lining up the rear swingarm, to the counter sprocket, and then to the front wheel.
Somewhere in the 20 something pages of this post is a pretty good explanation. Complete with dimensions. One of your chief concerns is the fact that Kawasaki had about a 2.5mm tolerance form centerline of front wheel to centerline of rear wheel. this comes into play, as the numbers I came up with may not match your bike.
I built a jig, and used it to line front and rear within .005".
The next issue will be frame and exhaust header clearance to the ground. There needs to be about 4 inches clearance between the bottom of the header, and the surface of the ground. You do not want to bottom out and slam the header.
Kossman made the steering stem for me, they are quite comfortable with this work, and know what they are doing. The new stem was then pressed into the GSXR triple clamp and the front end was good to go.
The swingarm aside from alignment is almost a bolt on deal. The bushings in the old KZ frame needed to be reamed a little to get the ZRX swingarm bolt through them, but not much. It then pretty much fit right in.
I have both a 99 ZRX and the KZ in my garage, I could measure some stuff if you need it. But first take the time to study this post from start to finish, I bet most if not all the info is already here. I tried to use the forum as a log of sorts.
There are a whole bunch of very supportive riders on this forum, and they have all run into the little hang ups you will find along the way.
The re-build was time consuming, but not all that hard.
Good luck, you have a great bike to start with.
Ducati S4R
Husqvarna FE 350s
Ducati S4R
Husqvarna FE 350s
The following user(s) said Thank You: greenman43
- homert1
06 Jun 2013 10:14
Thanks for the info..........I've been following a few builds on this site for a while. I haven't pulled anything apart yet as I am slowly gathering parts ( swingarm / forks etc ) Right now I'm trying to get running properly........I'm planning on picking up new coils and DYNA S ignition next week from Z1 enterprises. I have a line on a 1990 gsxr 750 w/blown motor and was planning to use suspension parts from this bike as I see some of our other KZ owners have done. BUT I think in one of your posts you commented you switched from GSXR 750 to 1000 front end due to height?? Is this true??
Because I want to ride this bike as a commuter when done I don't want to run into any ground clearance issues.
