Swing swap, finally a ZRX swing
  • Z1109R Fin
  • Z1109R Fin's Avatar Topic Author
23 Dec 2008 01:19
#254238
Santa came early this year :woohoo:
Got the new swing and rear wheel easterday. Since Xmas is so close I decided it was best not to spend too much time in the carage and I enjoyed vacuuming and mopping the floors all evening like a good, loving husband that I am So just a rough mock-up and it is really close to fitting without any big mods. It´s gonna look real mean. It´s 50mm shorter than the GSXR swing that was there and it´ll also ride a bit higher now. Can´t wait to start working on it
Z1000R ´83...Slightly modified...
  • Z1109R Fin
Re: Swing swap, finally a ZRX swing
23 Dec 2008 01:20
#254239
How do you attach more that 1 pic per message?
  • Z1109R Fin
23 Dec 2008 01:21 - 23 Dec 2008 01:22
#254240
Darnation:laugh:
This is th old one from a GSXR ´90 going to a friend of mineB)
Last edit: 23 Dec 2008 01:22 by Z1109R Fin.
  • Z1109R Fin
23 Dec 2008 01:23
#254241
Gonna be awfully tight with the exhaust. Looks like it´ll work witout modding...
  • Old Man Rock
  • Old Man Rock's Avatar
23 Dec 2008 04:36
#254249
ewwwwwwww.... Yummy! B)
Plans for the swing arm?
Painting, powder coating, buffing out etc...
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • Z1109R Fin
29 Dec 2008 05:10
#255223
Well, definately have to do something since PO has started buffing but seem to have ran out of elbow grease after the left side :laugh:
I think I´m going to semi-gloss alu finish. Not too shiny cause it´s not the style I want. Wanna go more to green/black -sceme. Well, time will tellB)
  • barney
  • barney's Avatar
29 Dec 2008 09:28
#255243
Looking good. Did you relocate the lower clevices that the shocks mount to ?
  • Z1109R Fin
30 Dec 2008 04:57 - 30 Dec 2008 05:08
#255338
Nope, at least not yet. I´ll have to check first how high it sits. I like it to be higher than earlier as long as there are no issues in handling. And even then I´ll try a steering damper first.
Last night I checked closer how it fits and it seems that all I have to do is shave 1mm off the right side axle collar and 1,5 mm of the swing.
Last edit: 30 Dec 2008 05:08 by Z1109R Fin.
  • KawiConvert
  • KawiConvert's Avatar
30 Dec 2008 09:49
#255367
How wide is the pivot bolt area? Would it fit a 650 without a lot of material removal? Also, how much longer is it? I am interested to see what else I can do to my bike now. Looks good.
1978 KZ650 D1 ~ Carb jetting: 107.5 & 20 & 4th groove with pods and 4-1 Exhaust
  • supercharged
  • supercharged's Avatar
30 Dec 2008 17:41
#255442
I hear of members 'trimming' the swingarms to fit. Do you take them to a machine shop? Grind at them with a ginder?
How does one accomplish this?
Mike D
- 79 KZ1000 LTD Supercharged
- 80 KZ1000 1105cc Pridmore/Vetter tribute
- 79 Honda CBX
- 03 Z1000 Mod
- 80 KZ1000 LTD Modified
- 80 KZ1000 LTD PROJECT on Hold
- 78 KZ1000/900 - Street big block
- 78 KZ1000-NEEDS HELP!
- 80 CBX -Project STARTED
- 81 GPZ1100
- GSRX1200
- 80 CB750F supersport... eahhh not so good
- 1988 KZ1000 Police - 50K miles
- 1978 KZ1000 LTD - should be a quick project
- 2001 KZ1000 Police - 30K miles - chromed Sgt Bike GREAT SHAPE
  • KawiConvert
30 Dec 2008 20:18
#255464
I did a dirtbike swingarm with a file and a lathe for the bushings. Depends on how the bearings and bushings are setup. Mill for accuracy and grinder if accuracy isn't needed.
  • Z1109R Fin
31 Dec 2008 03:59
#255491
Kawiconvert: ZRX swing is 235mm (I´ll recheck this since I don´t have my notes here) wide at pivot.
Supercharged: I´m going to shave the swing my self with a file and sandpaper as there´s no need to have absolute exact cut. But the axle collar must be done on a lathe as it´s the last part of the axle assy that is tightened betweet frame.
Also there´s the huge diff in pivot axles. Original is 16mm and ZRX is 20mm. Using the ZRX axle would mean bid modding on frame which I definately don´t want to do. Therefore I`m planning on having an extra sleeve made between original axle (outer diam 15,8mm) and ZREX axle sleeve (inner diam. 20mm). This time I want to make the swap "by the book" i.e have all original bearings and assembly from a ZRX fitted to ELR stock axle. This way I can be absolutely shure it works and can take some beating.
